remote turn on
Old Nov 29, 2003 | 03:21 PM
steve777's Avatar
remote turn on
hey i'm trying to hook up the remote wire to a fuse and every fuse that i hook it up to makes the amp turn on when the car is off...i thought that it would only turn on when the car is on??? There is no power antennae so i cant hook it up to that. What fuse should hook it up to??:
moonroof motor
drivers power seat-reclining,memory seat
heated seat
driver's power seat sliding,memory seat
passenger's power seat sliding
passengers power seat reclining
right power window
radio, power outlet
navigation system, day-time running lights
interior light, seat memory, homelink
power door locks
clock, backup, small light
ABS motor check
driver's power window
i tried almost all of them and they all did the same thing. I think if i hook up a switch to it, I can turn the amp on and off like that, but then i would have to flip it off every time i get out of the car so i would prefer to have it hooked up to a fuse that that the amp turns on when the car is on and off when the car is off. Thanks for any help.
Old Nov 29, 2003 | 04:27 PM
jblaze_RENAMED's Avatar
Commander in Chief
the radio fuse should run off the ignition switch. Just make sure you don't have that feature that your radio stays on till you open a door.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
Azonics
Sep 22, 2015 05:28 PM
GraveDigger
Sep 18, 2015 07:46 AM
Sep 17, 2015 09:01 PM
