Remote Turn-on
Old May 30, 2003 | 02:32 PM
SmurfCL's Avatar
7th Gear
Remote Turn-on
Hi all,
Does the 03 CL head unit have a remote turn-on lead? I am planning to install an EQ and an amp myself, and both of them have remote turn-on leads to connect with the lead in the HU. How you guys connect that to the OEM HU?
Old May 30, 2003 | 02:39 PM
NSXNEXT's Avatar
http://silverknight.clickhere2.net/sound.html
Old May 30, 2003 | 06:38 PM
SilverKnight's Avatar
Retired. Not available.
you may have to copy and paste link.
nsxnext,
when can you Zaino my silver CL?
You were the reason I ordered the Z stuff.
Old May 30, 2003 | 08:28 PM
NSXNEXT's Avatar
nsxnext,
Any time. Next time I'm in Houston I'd be happy to show you Zaino secrets.
Old May 31, 2003 | 12:15 AM
SmurfCL's Avatar
7th Gear
I am so dumb. I read the whole instruction from Silver Knight, and didn't see "remote turn-on" anywhere
The only thing I can see is the Radio Switch (YELLOW/WHITE) . Is it the one that I should use? If it is not, can you point it out for me, please?
This is my first time to mess with car audio, so be ... gentle with me
Old Jun 1, 2003 | 02:08 PM
shalinz's Avatar
I just installed an amp and subsover the weekend. I connected by remote wire for the amp to the radio switch wire based on the diagram from the other link in this post. It worked with no problems. When you turn off the HU then your amp will shut down too.
Old Jun 1, 2003 | 06:35 PM
ricardo's Avatar
thats cool... I hooked mine up to the ignition 'cause I was too lazy to pull apart my dash :p
Old Jun 2, 2003 | 01:29 AM
ricardo,
you should not have to mess with the dash. Do it at the trunk, right where the Bose amp is. BTW, the chart in my sound template is at the trunk, not at the HU.
Old Jun 2, 2003 | 08:07 AM
SmurfCL's Avatar
7th Gear
Thanks for all your help, guys. I installed the EQ last weekend. It's sloppy job, but I am very happy with it. Took me more than 2 hours to get to the HU and remove it. The four screws on the sides are the real pain-in-the-butts.
I didn't use any line-output converter or RCA converter, or any ground-loop isolater at all. Just got 2 set of regular RCA cables, cut them into 4, and soldered. Work great. No hiss, no hump, no whine (spelling?)
datadr
Mar 23, 2016 01:39 PM
eastcoastguy
Oct 29, 2015 03:00 PM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
saturno_v
Sep 27, 2015 08:13 AM
