remote start
Old Aug 17, 2003 | 06:22 PM
adoshi19's Avatar
remote start
hey guys, is it possible to install a remote start system and still use only the factory remote so i don't lose my memory seat feature, i have an 01 3.2 cl...thanks
Old Aug 17, 2003 | 07:01 PM
suXor's Avatar
Still trolling
You will have to sacrifice the remote trunk pop. SOmething from your remote has to trigger it.
Old Aug 17, 2003 | 07:23 PM
icy CL's Avatar
Re: remote start
i installed this to an aftermarket keyless entry/alarm system that i have on my 91 accord. i used the remote of my keyless entry cuz it had a button i wasn't using. based on the manual that came with the remote starter, you can program the brain to start the car with a combination of buttons pushed. eg: lock-unlock-lock....then the car starts. you can also get the transponder overide to work with it. not sure if this is what your looking for.
http://www.mypushcart.com . click on remote starts under auto security products. then select #9901. the range is not that long but good enough for me from the balcony of my apartment and for my 91 accord.
Old Aug 17, 2003 | 08:58 PM
StreetEffectz's Avatar
Yes, you can do this quite easily.....I'd recommend using a DEI Valet Remote Start unit, model 551T.....you can set it so 3 presses of the lock button back to back to back will start the car....only downside, the range on the factory remote stinks
Old Aug 18, 2003 | 02:16 AM
dnd2984's Avatar
How much does remote start cost, with keep the factory remotes and the DEI unit?
Old Aug 18, 2003 | 09:44 AM
fuzzy02CLS's Avatar
Will this work on a manual?
Old Aug 18, 2003 | 09:54 AM
JakeCL's Avatar
yea will it? the first one (crimestopper 9901) says AT only would there be a way around it?
Old Aug 18, 2003 | 10:00 AM
BEETROOT's Avatar
Yeehaw
I have never seen a remote start that works on a manual...don't know why but I don't think its possible...maybe since the clutch needs to be down to start it?
Old Aug 18, 2003 | 10:15 AM
brianlin87's Avatar
ASM I.S. Design FTW.
i had it in my prelude... you just have to park in gear, it works the same
Old Aug 18, 2003 | 10:25 AM
BEETROOT's Avatar
Yeehaw
park in gear?? but then if the car is turned on, its in gear, clutch is not engaged...wouldn't it just stall immediately?
Old Aug 18, 2003 | 11:44 AM
fuzzy02CLS's Avatar
The ones that are legal only start with the car in N, & the parking break on. If you start it with the car in gear, the car would fly forward on it's own, That would not be good.
Old Aug 19, 2003 | 10:36 AM
JakeCL's Avatar
it would scare the shit out of someone leaning on it though
Old Aug 19, 2003 | 08:44 PM
lippey's Avatar
9th Gear
as far as getting the remote start to work on a manual - it's easy...
all you have to do is either by pass teh clutch switch - it is a button like thing that gets depressed when you press down on the clutch in order for the car to start. the hondata has a similar switch that you wire up in the stage 3 units and above (my old car). you can also ghetto rig the thing and tape the switch down and the car will not only start normally with the key without pressing the clutch down, but you will also be able to auto start it as well.
audio and security stores do not do the install on manuals due to liability reasons with idiots who leave their car in gear with the autostart feature adn slam into the car parked in front of them.
let me dig up a pic to help explain this...
ryan
Old Aug 19, 2003 | 08:58 PM
lippey's Avatar
9th Gear
http://vtec20.8k.com/misc/picture.doc
open the word document to see what i am talking about...
peace
oyayjoe
Jan 1, 2019 10:17 PM
oyayjoe
Sep 12, 2015 04:40 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
jordanboi
Sep 5, 2015 01:33 AM
datadr
Sep 2, 2015 06:46 PM
