Remote Audio Controls
Old Oct 23, 2006 | 06:12 PM
ssebby70's Avatar
Unhappy Remote Audio Controls
Hi there...I just enter the code for the audio system and the remote audio controls on the wheel are acting weird.When I press the low volume is skiping tracks ....etc... any ideas how to fix this?..thanks
Old Oct 23, 2006 | 08:38 PM
death's Avatar
Problems with controls on the steering wheel are usually due to problems with a metal ring found within the steering column. The dealer should replace this under warranty (assuming you’re within your warranty limits). I had the same problem within the first 5,000 miles. Sorry but I don't think there is a quick fix for this problem. I hope this helps.
Old Oct 24, 2006 | 08:08 AM
fsttyms1's Avatar
like said above there is no quick fix. if under warranty bring it in. Otherwise you have to remove the steering wheel to get to it. Its not hard and if you plan on attempting this I have a PDF on how to do it and fix it
Old Oct 24, 2006 | 08:24 AM
ssebby70's Avatar
PDF file
Hello there,
My car is not under the warranty anymore. I think would be worth looking at the PDF file. Thank you
Sebastian
Jul 16, 2017 07:33 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
