Remote for aftermarket amp
Old Mar 25, 2005 | 05:26 PM
euroStyle's Avatar
I was in the process of installing amp and sub.
I think i have a problem with remote tapping.
i was told that the yellow with green line is the remote line for the factory amp.
so I tapped b7 line(the audio unit ,radio switch) from the wiring harness from the factory amp.
so did i do something wrong or can it be the amp thats not working.
Old Mar 25, 2005 | 06:57 PM
elduderino's Avatar
VP Electricity
That is the right wire.
1) Do you have a test light or voltmeter? It would be good to test this wire WITH and WITHOUT your connection. Has your FM reception gone south? If so, you might not have an RTO OP and the FM amp is not being powered...
2) Disconnect the RTO wire from the new amp. Take a short piece of wire or a paper clip and jump it from the 12V constant tap to the RTO tap on the amp power strip. If the amp comes, on the amp is OK. If it does NOT, the amp is bad.
Old Mar 25, 2005 | 07:10 PM
euroStyle's Avatar
the FM still works. let me test it out.
Old Mar 25, 2005 | 07:18 PM
euroStyle's Avatar
hm... i think the amp is bad. damn.
but i'll make sure and get a voltmeter and check it.
Old Mar 25, 2005 | 07:32 PM
elduderino's Avatar
VP Electricity
You remembered to put the fuse in up at the battery, right? ; )
Old Mar 25, 2005 | 08:36 PM
euroStyle's Avatar
yep.
tomorrow, im going to take it to a shop to get it checked.
Old Mar 26, 2005 | 01:38 AM
euroStyle's Avatar
ok, found the problem. the ground point wasnt great. where is a good place it ground it?
Old Mar 26, 2005 | 03:39 AM
nismo's Avatar
Audio/Video/Alarm Expert
anywhere on the chassis of the car, make sure you sand off the paint where you do contact it. Paint prevents continuity.
Old Mar 26, 2005 | 09:44 AM
elduderino's Avatar
VP Electricity
I like a factory bolt under the trunk liner - a ground bolt if you see one. I wouldn't run all the way up to the nav ground bolt though. I like the factory bolts just because they don't loosen with time like a screw can.
"prevents continuity"? Who talks like that? We all know that paint simply doesn't contain the valence electron! : )
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
vpasla1
Sep 17, 2016 07:24 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
