radio shut off
Old Jun 13, 2005 | 10:43 AM
NICKTL's Avatar
radio shut off
weird thing happened this weekend. i put in an aftermarket radio in my tl a few weeks back and everything was kosher. but this weekend when i shut the car off and pull out the key the radio still plays for about a min and then shuts off. what is the deal?
Old Jun 13, 2005 | 11:05 AM
elduderino's Avatar
VP Electricity
Doesn't the retained accessory power circuit feature power the radio and power windows after the key is turned off, UNTIL a door is opened? (Or until the timer runs out?)
In other words, I think you had this feature the whole time : )
Old Jun 13, 2005 | 11:28 AM
skippy911's Avatar
6th Gear
This same thing happened to me the other day with my stock headunit. I found out it had something todo with the inverter I had plugged into the cig lighter outlet. As soon as I took it out the radio shut down normally. Now today with the inverter plugged in everything shuts down normally with no problem.... weird huh?
Old Jun 13, 2005 | 11:33 AM
NICKTL's Avatar
that is it!! i just put an invertor in my console this weekend. never thought that that would be the case. but now yours is working fine with it plugged in? weird. i'll unplug it and see if the radio shuts down normally. thanks for the help. thought my car liked the bass and wanted to finish off the song before it went to sleep.
Old Jun 13, 2005 | 12:32 PM
elduderino's Avatar
VP Electricity
If that's it, the inverter has a large capacitor on the input that is backfeeding into the car, and it doesn't have a large internal diode to prevent that from happening.
You could insert a large diode or diodes in parallel into the power wire for the inverter to prevent that from happening - what's the current rating of the inverter? How many amps does it draw?
Old Jun 13, 2005 | 01:17 PM
NICKTL's Avatar
not quite sure on the draw power. it is made by prestone and is yellow. if i leave it the way it is are there any neg affects?
Old Jun 13, 2005 | 02:10 PM
elduderino's Avatar
VP Electricity
This inverter is made out of ethylene glycol? (Never mind...: )
Sounds like a POS inverter to me. SHouldn't do that.
Everything in the car should KNOW the instant that key turns off. ECU's, alarms, everything.
dirleton
Aug 6, 2024 08:19 PM
Puma Jim
20
Oct 20, 2016 11:59 AM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
chiu0nthls
3G MDX (2014-2020)
Sep 28, 2015 03:46 AM
prbori
Sep 27, 2015 01:37 AM
