Radio Problems.....
Old Nov 14, 2002 | 09:32 AM
scanrjok's Avatar
Radio Problems.....
After fiddling around yesterday, something went wrong. I have a 1997 2.2CL. The radio no longer works, the car doesn't remember that the climate control was on (when turning off the car and restarting), and the clock only works when I press in a button on the cover of the buttons that set it. The security system no longer chirps when arming/disarming. What could this problem be? I have things connected to the radio and clock fuses and they work fine. Please help me!!!
Matt
Old Nov 14, 2002 | 09:50 AM
shawhite_RENAMED's Avatar
sounds to me like a loose connection somewhere... i say this cuz there is way to many problems for just a fuse or wire to be bad... check all connections...
Old Nov 14, 2002 | 12:26 PM
scanrjok's Avatar
I have looked at the connections I could find, they seem ok..... where could this connection be since if affects many things???
Old Nov 14, 2002 | 03:12 PM
acur8ly's Avatar
Check the fuse box connection. That one connection may power all those comonents
Old Nov 15, 2002 | 11:15 AM
Slooo97CL's Avatar
Check the small light fuse...I think 2 fuses blow one on the inside fuse box and one under the hood...that happened to me before also.
dirleton
Aug 6, 2024 08:19 PM
Puma Jim
20
Oct 20, 2016 11:59 AM
SinCityTLX
20
Oct 19, 2015 11:23 AM
jdmaszfcuk
Oct 19, 2015 12:31 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
