radio help
Old Jan 18, 2009 | 04:26 PM
taintedplay's Avatar
radio help
sorry if this has been asked before
basically my dad owns a 3.2tl type s. His radio got jammed, so he bought another one off of ebay. He looked and the connectors are wrong on the back. so we took the peices apart (the radio and cd changer are different parts)
We put them back together, with the old radio but new cd changer. The radio worked, but the cd changer said CHEC and then after a while ER ER1. Any ideas?
or would it be better to get a new head unit. Can a head unit work with the stock speakers/sub and still work easy?
Old Jan 18, 2009 | 04:43 PM
fsttyms1's Avatar
Sounds like he got a CL headunit. while they look similar they aren't and aren't compatible. Id get one that is for the TL.
Old Jan 18, 2009 | 04:48 PM
ahh. damn. ok, but does a aftermarker HU work with the stock speakers? ie like a pioneer fh-p800bt
Old Jan 18, 2009 | 05:44 PM
fsttyms1's Avatar
Yes. There is nothing special about our system/speakers. Only thing is you will have to do some custom wiring to get the stock sub to work with a aftermarket radio. Its not hard.
Old Jan 18, 2009 | 05:46 PM
is there a tutorial on how to do the wiring to make the sub work?
Old Jan 18, 2009 | 09:27 PM
totaledTL's Avatar
Search....
Old Jan 18, 2009 | 09:54 PM
fsttyms1's Avatar
Originally Posted by totaledTL
Search....
Find it for him.
Old Jan 18, 2009 | 11:01 PM
gold2003tl (90)'s Avatar
2003 TL-p
https://acurazine.com/forums/audio-video-electronics-navigation-22/keeping-factory-sub-when-adding-aftermarket-headunit-99-03-tl-326253/
read and look at the picks on page 4. good luck
Old Jan 18, 2009 | 11:17 PM
thanks!
Old Jan 19, 2009 | 07:12 AM
totaledTL's Avatar
Originally Posted by fsttyms1
Find it for him.
Go ahead, you know where everything is.
Old Jan 19, 2009 | 07:19 AM
fsttyms1's Avatar
I told you to since you told him to. Of course i know where every thing is. You should too so you can help members like him when im not around so you dont have to post search.
Old Jan 19, 2009 | 11:22 AM
totaledTL's Avatar
Hmm, I thought you would encourage searching, I suppose I was mistaken-
Of course I do not know where everything is- I'm not a mod & do not spend as much time on here as one. More often than not I have done searches for others to assist but this poster did not mention searching first- Maybe he didn't know about the search function.
Old Jan 24, 2009 | 10:37 PM
ok im about to do this, just making sure i got it all right before i buy a HU.
so the stock speakers and speaker amp dont need anything special to work with a aftermarket HU, while i need to splice the sub wires to rca's to the headunit. does the sub have a amp or does it run off of HU power?
Old Jan 24, 2009 | 10:54 PM
newperson's Avatar
There's no Acura in
I think the stock amp is only for the [stock] sub.
Someone correct if wrong,
Code:
stock HU -> EQ -> EQ.bass -> stock amp -> stock sub
             |--> EQ.nonbass -> HU -> speakers
Old Jan 24, 2009 | 10:56 PM
so would i remoe the amp? or splice the rca's from between the sub amp and hu
Old Jan 25, 2009 | 02:57 PM
bump
Old Jan 26, 2009 | 09:00 PM
bump
Old Jan 27, 2009 | 07:59 PM
newperson's Avatar
There's no Acura in
I think this is what you're looking for?
https://acurazine.com/forums/2g-tl-performance-parts-modifications-116/retain-working-bose-sub-when-changing-aftermarket-headunit-690434/
I've been searching for your answer but I swear every reply in a thread I would read would be like "search for it, it's been done before already" but the original thread is no where to be found.
Old Jan 31, 2009 | 01:53 PM
im still really confused. i read those threads but not sure still. Ok, so i got the speakers working. so do i cut the connector off of the wires from the old eq? (green connector behind climate control)
also, on the rca inside leg, its like a insulation. do i strip that?
Old Jan 31, 2009 | 03:09 PM
edit: ok forget the last post, this is where im at. i did the rca to the two wires, and i attached the remote wire from my new HU to the blue power antenna off of the metra harness. its not working, am i missing something?
Old Jan 31, 2009 | 11:19 PM
anyone?
dirleton
Aug 6, 2024 08:19 PM
Puma Jim
20
Oct 20, 2016 11:59 AM
SinCityTLX
20
Oct 19, 2015 11:23 AM
jdmaszfcuk
Oct 19, 2015 12:31 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
