Radio doesn't shut off right away
Old Jun 7, 2002 | 06:06 PM
Zeus's Avatar
Does anyone else's stock headunit not shut off right away when the ignition is shut off and the key is removed. Sometimes it takes up to ten seconds before it shuts off.
Is this normal?
Old Jun 7, 2002 | 10:18 PM
kensteele's Avatar
Re: Radio doesn't shut off right away
Is this normal?
This is not normal. Mine shuts off right away; every time.
Old Jun 7, 2002 | 10:37 PM
Zeus's Avatar
Dooh!
Does this happen to anyone else? How do I fix this? The freakin car is four months old!
Old Jun 7, 2002 | 10:49 PM
mattrush78's Avatar
The Quite One
The best way to fix the problem is to have your dealership install a new radio for you. It could also be a wiring or electrical problem. So you really need to talk to your dealership about the problem. They should fix the problem under warranty.
I hope that this help you. Best of luck to you on your problem!
Matthew
Old Aug 1, 2002 | 09:13 PM
Zeus's Avatar
They replaced the cig ligher plug under warranty. The problem went away. They said there was a bulletin about this.
Thanks for the help.
Puma Jim
20
Oct 20, 2016 11:59 AM
SinCityTLX
20
Oct 19, 2015 11:23 AM
jdmaszfcuk
Oct 19, 2015 12:31 AM
chiu0nthls
3G MDX (2014-2020)
Sep 28, 2015 03:46 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
