Radio doesn't shut off right away
Does anyone else's stock headunit not shut off right away when the ignition is shut off and the key is removed. Sometimes it takes up to ten seconds before it shuts off.
Is this normal?
Is this normal?
Re: Radio doesn't shut off right away
Is this normal?
Is this normal?
The best way to fix the problem is to have your dealership install a new radio for you. It could also be a wiring or electrical problem. So you really need to talk to your dealership about the problem. They should fix the problem under warranty.
I hope that this help you. Best of luck to you on your problem!
Matthew
Matthew
Puma Jim
20
10-20-2016 11:59 AM
SinCityTLX
20
10-19-2015 11:23 AM
jdmaszfcuk
10-19-2015 12:31 AM
