Radio Code Problem!!! HELP!
Old Nov 9, 2003 | 12:25 PM
Natismati's Avatar
Unhappy Radio Code Problem!!! HELP!
Well seems that i have removed the fuse for the radio or something and the radio is asking me for the code...one time before this i lost my card and had to get the serial number off the radio...pain in the butt....and had to call the dealer up for the code...well same position again but this time i have the right codee..i believe so anyways..because last time this happened the code worked just fine....this time though i put the code in first few trimes but i messed up puttting in the wrong number that was on my paper with the code.......but i know its the right code..it is still giving me an "err" picture....can anyone help me p lease?
Old Nov 9, 2003 | 04:36 PM
NsX Pilot's Avatar
Did you try disconnecting the power to the radio again after and then re-inserting the right numbers ?
Old Nov 9, 2003 | 11:09 PM
Scott P's Avatar
Mobile Elec. Guru
on stock radios like this bose, you have only thre chances to enter the correct code before it goes to lock down. Make sure you have the right code, then pull the fuse for ten seconds to ensure that it resets then enter in the corect code.
Old Nov 10, 2003 | 11:05 AM
NsX Pilot's Avatar
This is exactly why i said to disconnect the power and try again....happened once in my legend.
Old Nov 10, 2003 | 12:13 PM
Natismati's Avatar
worked great guys!!! thanks alot!!!
Old Nov 10, 2003 | 09:11 PM
Scott P's Avatar
Mobile Elec. Guru
I had the same thing happen in my legend
mada51589
Jan 9, 2025 04:40 PM
handsom-hustla
Nov 13, 2015 05:04 PM
IndycarFaster
Sep 11, 2015 02:52 PM
HeloDown
Sep 8, 2015 06:51 PM
darknite123
Integra
Aug 30, 2015 03:00 PM
