Radar Detector Hard wire in the Overhead
Old Nov 10, 2006 | 10:14 PM
PhilB81's Avatar
I've read through the hard wire threads, and seems that some of you guys hooked into the fuse box, and some into the overhead, by the rearview mirror and the map lights.
I'm considering buying a V1 unit, and connecting it to one of the wires in the overhead.
I have not seen any CLs with that setup, only TSXs.
Is there a wire I could use in the overhead for a 2001 CLS?
Basically I want a wire that will turn off with the ignition, and obviously have enough amperage to run the V1 at it's full cappacity.
Thanks!
Old Nov 14, 2006 | 07:35 PM
gaping46and2's Avatar
SOLD: 03 SSM CLS Auto
You can possibly splice into the rearview mirror, but probably the best way to go is run the cord down to the fuse box on the driver side, and get an "add a fuse" from any autopart store. I used the side mirror heater fuse and plugged it into that, then used one of the bolts down there to ground it. Then again, I don't have a V1, and I believe they make a hard wire kit for the V1 anyway, so all this is probably not necessary.
Old Nov 15, 2006 | 08:42 AM
fuzzy02CLS's Avatar
My V1 is hooked in this way.
You can get a hard wire cord from Escort for a 7500(not the smart cord just the regular hard wire)
That has 2 simple connections, power with a fuse & ground. It's not a big thing like V1's hard wire kit.
I have my CL & Explorer hooked up this way.
I don't even have a fuse tap. I have the spliced 12V wire wrapped around the power mirror fuse & the ground at a bolt near the fuse box.
You can tap into the mirror. I've done that on other cars. Worked fine.
I think it's just easier to run the hard wire.
Old Nov 15, 2006 | 01:37 PM
PhilB81's Avatar
great, the V1 should be home today, so I'll look at what came with it, and how much cord I have, I hope it includes a fuse.
Thanks for the replies, I'll probably drag it to the fuse box as you guys recommended.
Old Nov 15, 2006 | 02:01 PM
fuzzy02CLS's Avatar
Oh yes it has everything you need. I just don't like the V1 kit cause it's a bit bulky & unnecessary IMHO.
Old Nov 16, 2006 | 10:56 AM
PhilB81's Avatar
hehe, i'll do the work this weekend.
can any of you show me a pic where u put the unit by the mirror? seeing where you guys mount it would be appreciated it.
if no images, a description would do just fine too, thanks
Old Nov 16, 2006 | 12:17 PM
fuzzy02CLS's Avatar
Directly under the mirror, center of windshield with a clear view of the font & rear.
Old Nov 16, 2006 | 09:44 PM
KaMLuNg's Avatar
is this the hardwire you are talking about???
https://www.escortradar.com/cp/cgi-b...irect_wirecord
i just thought the V1 was kind of bulky with the square box..
Old Nov 17, 2006 | 08:55 AM
fuzzy02CLS's Avatar
Yes that is the 1 I have.
Old Nov 20, 2006 | 07:59 AM
PhilB81's Avatar
Alright got mine hooked up over the weekend. the V1 thing is kinda big, but it fits 1/2 well in the fuse box area.
I initially tried to plug it in the daytime running lights fuse slot, but I realized it doesn't have those metal prongs to hold a fuse in, and the 12v line was WAY in there, and if you twisted around too much you can hit the chassie, making fun little sparks.
After some debate, I decided that although sparks are cool, I do not want them happening in my car, so I just put a wire in with the fuse for the heated seats as you guys suggested, tucked the wire in around the trim. (didn't even remove the plastic trim).
I like how easy to reach the unit becomes when mounted at the top of the windshield.
Thanks to everyone for the advice on hooking this up.
-Phil
Old Nov 20, 2006 | 12:05 PM
KaMLuNg's Avatar
i just sent my unit out to get upgraded.. i will hardwire when i get it back..
Old Nov 20, 2006 | 01:11 PM
fuzzy02CLS's Avatar
Glad to hear!
08KBP_VA
Oct 22, 2019 01:55 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
