quick question
Old Apr 15, 2005 | 08:12 PM
nitehawktsx67's Avatar
2004 NBP/ebony AT
quick question
ok the subs im looking at are kicker 12" l7s or some l5s what ever i get ill be running rms to both of them for 2 l5s its 1200 for 2 l7s its 1500, are the l7s worth the extra money and wattage? is it ok to run 1500 watts in a tsx? thanks guys
Old Apr 15, 2005 | 08:17 PM
elduderino's Avatar
VP Electricity
Dude, take some of these
Insert them into your post, and then I'll see if I can figure out what you mean and I'll do my best to help you out, honest.
Old Apr 15, 2005 | 11:35 PM
2004 NBP/ebony AT
ok sorry im looking at three choices right now, 2 12" L7s, with a hifonics 1500 watt amp,2 12" L5s with a hifonics 1200 watt amp, or 2 15" L5s with the hifonics 1500 watt amp. my questions where can the tsx handle 1500 watts? which of those might sound the best and be the loudest? does 300 watts really make that much of a difference? thanks
Old Apr 15, 2005 | 11:43 PM
elduderino's Avatar
VP Electricity
If you want 100 watts to sound louder, you need to double it to 200 watts, given the same set of speakers and all else remaining the same.
The diff between 1200 and 1500 watts will NOT be a volume diff. THere MIGHT be a diff in SQ, but that diff will be far, far greater between different woofers than between 1200 and 1500 watts of amp power. Regardless, I thyink you'd be starving on your alternator output with with either. Sounds like you want to be really opbnoxious! I would suggest going with 500 W of power and a ported box that's custom made - would have more output and less money.
Bass Mechanic and others have said some things about newer Kicker woofs that you might want to read up on...
Old Apr 16, 2005 | 01:35 PM
2004 NBP/ebony AT
ok well today i went and looked at some kicker subs and the guy said that the L5s or L7s arnt really waht i need and should go with two 12" compVRs with i think he said 400 watts and a ported kicker livin loud box. he said it would be about 725 installed. does this sound good to yall?
Rdub81
ILX Photograph Gallery
Mar 17, 2016 03:02 PM
06TLMatt
Oct 2, 2015 08:14 PM
Strath
Sep 27, 2015 11:53 PM
HOWELLiNC
Sep 20, 2015 04:21 PM
datadr
Sep 12, 2015 09:12 PM
