quick question
Old Feb 25, 2002 | 05:51 PM
jz983's Avatar
quick question
what guage should i use? i have alpine SPS6939S for rears and Boston acoustics FX5 fronts. 14 ga? 16ga?
i am running them with a RF Punch 400.4 amp.
and also...
i have 2 RF Punch 400.4 amps, 1 RF 1 Farad Capacitor and a stinger distribution block (4ga --> 2x8ga). One amp for speakers, one bridged for dvc sub. i plan on using 4 gauge power from battery to the distribution block, then 2 8ga for each amp. a question. for the capacitor ground wire, does it matter if it is 4 ga or 8 ga?
hope i didn't confuse any of yall.
thanks.
Old Feb 27, 2002 | 03:37 AM
Austin519's Avatar
jz983:
Mmmm best bet on wiring is whatever your amp accepts. That's the best way to determine what gauge to use in and out. I'd suggest 12-16ga wire. You want all your power wire to be the same gauge...so if your power cable is 4 gauge going to your dist block, you want 4 ga for the cap. How do you plan on hooking the cap up? Because it should be run through the + of the power wire before the dist. block, in which case it's obvious it needs 4 ga.
Austin519
Rdub81
ILX Photograph Gallery
Mar 17, 2016 03:02 PM
06TLMatt
Oct 2, 2015 08:14 PM
truonghthe
Oct 1, 2015 03:13 AM
Strath
Sep 27, 2015 11:53 PM
HOWELLiNC
Sep 20, 2015 04:21 PM
