questions regarding installing indigo gauges.
Old Feb 14, 2002 | 07:19 PM
UW RL's Avatar
The Doctor
yo Nate, where should I mount the modulator and the switch? as for the power source i am just gonna tab it into the fusebox, exactly where i connected the power for my shock sensor.
i will install it tomorrow or maybe tonight (valentine's day!)
Old Feb 14, 2002 | 08:11 PM
Nate's Avatar
Anywhere you want really. I'd just zip tie the invertor somewhere under the dash and stick the button under there somewhere reachable.
Using the power you use for your shock sensor? Won't that keep it on all the time? There should be an unused tab on the backside of the driver's side fusebox that gets power when the headlights come on. You can buy a connector that slips on the tab perfectly. The tab you are looking for has a letter "t" in a circle and the number 3 next to it.
Old Feb 14, 2002 | 09:41 PM
UW RL's Avatar
The Doctor
you mean prongs?
Old Feb 18, 2002 | 11:31 PM
BirjuP's Avatar
where can you get the indiglo gauges?
Old Feb 18, 2002 | 11:36 PM
KaMLuNg's Avatar
if u tapping into the fuse box i would hook it to the parking lights fuse... easiest way to get into there is find which side has constant power (need ohm tester) and wrap the power wire around the OTHER tab of the fuse then stick the fuse back in... this is easiest thing to do... and ur guages will turn on with ur parking lights like they suppost to... mount the button somewhere reachable and outta site... and the modulator i just taped it somewhere underneath where it wouldn't move... hope that helps if u didn't already do it....
hues10
1G RDX (2007-2012)
Sep 7, 2016 03:47 PM
Skirmich
Sep 15, 2015 06:41 PM
datadr
Sep 12, 2015 09:12 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
