Question on Dom's Navi converter
Old May 12, 2006 | 12:31 PM
Masterpoolcat's Avatar
I was wondering if there is a way to toggle between all 3 different inputs (nav, aux1, and aux2) manually on Dom's navi converter. I know that you can install a switch to toggle between the nav and aux1, but that doesn't let you toggle between the 2 aux inputs. Any help will greatly be appreciated. Thanks.
Old May 12, 2006 | 12:51 PM
Reach's Avatar
Wire another switch and 12v to the blue/white combo, or get a 3-way rocker switch and set them all up together, that should do it.
Old May 12, 2006 | 01:53 PM
Will this solution still enable the backup camera to come on automatically when the car goes in reverse?
Old May 13, 2006 | 09:39 AM
Reach's Avatar
No, that makes it a manual toggle. I suppose its 'possible' to make it so with an extra relay in front of this setup, but I'd be giving you bad advice if I said I knew how to do it.
Try an install shop if you want a setup that complicated.
Old May 13, 2006 | 10:36 AM
fuckleberry's Avatar
bymotion
Nov 18, 2015 11:28 AM
IIDXholic
Oct 8, 2015 07:53 AM
datadr
Sep 12, 2015 09:12 PM
ivegotthenav
Sep 11, 2015 07:51 PM
alan_rich
Sep 7, 2015 11:08 PM
