Question on Dom's Navi converter
Old 05-12-2006, 12:31 PM
Masterpoolcat's Avatar
I was wondering if there is a way to toggle between all 3 different inputs (nav, aux1, and aux2) manually on Dom's navi converter. I know that you can install a switch to toggle between the nav and aux1, but that doesn't let you toggle between the 2 aux inputs. Any help will greatly be appreciated. Thanks.
Old 05-12-2006, 12:51 PM
Reach's Avatar
Wire another switch and 12v to the blue/white combo, or get a 3-way rocker switch and set them all up together, that should do it.
Old 05-12-2006, 01:53 PM
Will this solution still enable the backup camera to come on automatically when the car goes in reverse?
Old 05-13-2006, 09:39 AM
Reach's Avatar
No, that makes it a manual toggle. I suppose its 'possible' to make it so with an extra relay in front of this setup, but I'd be giving you bad advice if I said I knew how to do it.
Try an install shop if you want a setup that complicated.
Old 05-13-2006, 10:36 AM
fuckleberry's Avatar
bymotion
11-18-2015 11:28 AM
IIDXholic
10-08-2015 07:53 AM
datadr
09-12-2015 09:12 PM
ivegotthenav
09-11-2015 07:51 PM
alan_rich
09-07-2015 11:08 PM
Quick Reply: Question on Dom's Navi converter
