question for amp fuses
Old Aug 19, 2002 | 11:13 PM
kimxhiep1017's Avatar
i'm running 2 amp are PG ZXTi600 and jl audio 500/1 both amp are rated 110 amps fuse . so what i have to use amps fuse for the front battery. please help
Old Aug 19, 2002 | 11:19 PM
mattrush78's Avatar
The Quite One
Are you going to run any caps in your system? Have to bought a fase holder yet?
Matthew
Old Aug 19, 2002 | 11:41 PM
yes i have a fuse holder and dist block and don't plan to use a cap cause i have an aftermarket alternator
Old Aug 20, 2002 | 12:27 AM
mattrush78's Avatar
The Quite One
If you are using the Phoenix Gold Zeropoint fuse holder. I would recommend a 200 amp fuse. If you are using the Phoenix Gold XS or QX Series Fuse Holders. I would recommend replacing it with the Zeropoint Fuse holder or the 200 amp Phoenix Gold circuit Breaker. The reason why is, because the XS or QX type fuse holder only support up to an 80 amp fuse. If you had a cap or two I would recomend a smaller fuse. I ran a Alpine MRV-1507 and a JL Audio 300/4 on the stock alternator with two one farad caps with one 80 amp fuse and I was ok. Sense you don't have caps you will need a bigger fuse.
Hope that help!
Old Aug 20, 2002 | 01:40 AM
SilverKnight's Avatar
Retired. Not available.
You better check your JL 500/1 fuse rating again. I think the recommented fuse is 80Amp or lower, not 110Amp.
Old Aug 20, 2002 | 02:23 AM
the JL 500/1 using 50 amp fuse and PGZXTi 600 is rated 60 amp fuse for 4 ohms stereo so both are 110 amps fuse.
Old Aug 20, 2002 | 08:59 AM
mattrush78's Avatar
The Quite One
Then a 100 amp fuse should be fine.
Old Aug 20, 2002 | 09:37 AM
100 amp fuse is will blow when the music peak, is it true?
Old Aug 20, 2002 | 09:54 AM
mattrush78's Avatar
The Quite One
Both of your amp would have to be a peak power to blow a 100 amp fuse. Your bass amp could hit peak power very fast, but your full range amp is less likely to hit peak power unless you have your gain all the way up. You should be fine with a 100 amp fuse. If you start to blow fuses then I would recommand getting a cap to help with just problem.
06TLMatt
Oct 2, 2015 08:14 PM
truonghthe
Oct 1, 2015 03:13 AM
ROSSARONIE
Sep 22, 2015 11:46 AM
datadr
Sep 12, 2015 09:12 PM
