Question about amp install
Old Mar 9, 2001 | 07:15 AM
[VTEC]TL's Avatar
RWD convert
Post Question about amp install
I wired my amp and subs but the amp is not turning on. I wired the remote to the blue turn on wire etc. Could it be because I'm using 18 guage wire for the power and ground??? WOuld using a 4 or 8 guage wire fix My problem??? I'm running a 600 watt amp to push My 2 JL 10's BTW.
Y2K Satin Silver/Ebony 3.2TL
AEM SRI w/ custom CAI conversion | Magnaflow axle-back quad exhaust w/ modded downpipe | Neuspeed Sport springs(modded: 3.5"F/3"R drop) | Acura OEM Wing | Mesh grill | "Euro" Headlight finishers | Graphics by GBM | Acura Indiglo Emblem | Mugen badging | Body color door handles | Polarg M-12's/Eurolite Hyper Blue's | Opti-Blue Xenon High beams | Hiper Strobes | 20%/35% Llumar tint | Razo RA42 Shiftknob | Alloy pedals | Dual 10" Blue neons in bumper | 200 watt Audiovox bass tube | Escort Passport 7500
Old Mar 9, 2001 | 02:31 PM
[VTEC]TL's Avatar
RWD convert
Post
Ok I switched to 8 guage wire and still no cigar. The ground light comes on but the power led doesn't. Which wire from the factory amp do I use for the rempte turn on???
Old Mar 9, 2001 | 03:54 PM
StreetEffectz's Avatar
Post
Sounds to me like the remote turn on lead isn't gettin' enough current. If this amp is just for subs, I would wire the remote lead to a seperate switch, this way you can turn it on and off at will and not always have bass playing.
If you are using the stock amp remote wire to turn on your aftermarket amp, chances are, IT WON'T. You need to put a relay in line with this to supply enough power to your aftermarket amp.
Old Mar 9, 2001 | 05:35 PM
96TL's Avatar
Ex-Mod
Post
Thats what I have to do...
Old Mar 10, 2001 | 08:12 AM
preludeshfan's Avatar
Post
Uhh i would be suprised if you can find a relay that the factory head unit can turn on. the factory head unit has a very low current output. you will need a transistor to boost the current. damn i have already posted about this before and nobody listens!
look back about november-december for my post on the subject i had it all spelled out and i don't feel like typing it all over again.
formerly 98 prelude type SH
Currently 2001 Acura 3.2 TL With Navigation Black/Ebony
Old Mar 10, 2001 | 02:06 PM
96TL's Avatar
Ex-Mod
Post
There are relays that work...I have one in my car...it's just a low current relay and works PERFECT
I have a low current relay for my Varad LEDs and if the factory alarm lead energizes the relay, then the factory remote lead will.
Old Mar 10, 2001 | 05:35 PM
AcuraTL's Avatar
OG
Post
The blue wire works for me, it turns on my Orion amp no problem.
Honda-Acura.net TL Forum Moderator.
1999 Silver with factory body kit, spoiler and burlwood instrument cluster and shift knob. Joshua Tree Wood dash kit. Hella air horns. Tint all around. Razo competition pedals. MOMO Sport 18"X7.5" with 225/40ZR Pirelli P7000SS. Weapon-R intake. Comptech springs, exhaust and headers. Inspire Tailights, homemade ram-air and Polarg M-12 front turn signals. Comptech front and rear sway bar. Axxis Metal Master front and rear pads. Mugen front grille. 2 Polk/MOMO 10" subs, Orion Xtreme 500.4 amplifier and Alpine CD changer.
My AcuraTL Homepage
NEW: '01 Acura MDX Silver Premium
Front 35% tinted windows. Running boards. Roof rack. Tailgate deflector. Moonroof visor. Rear mud guards. Razo premium white headlight bulbs. Matriz ion yellow fog light bulbs(courtesy of Snook). More to come later......
Acura-MDX.com Forum Moderator
Old Mar 10, 2001 | 06:18 PM
[VTEC]TL's Avatar
RWD convert
Post
So hooking the remote wire directly to the battery with a switch will work??? Also, what is a relay? How much and what kind? Where would I be able to pick one up?
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by [VTEC]TL on March 11, 2001 @ ]</font>
Old Mar 10, 2001 | 11:01 PM
Post
Old Mar 11, 2001 | 05:53 PM
[VTEC]TL's Avatar
RWD convert
Post
Anyone?
Old Mar 11, 2001 | 07:34 PM
AcuraTL's Avatar
OG
Post
Yes, wiring directly to the battery with a switch will work, but you wil have to remember to turn it on/off everytime you drive your car. Also, you will get a turn-on "thump" sound from your subs if you do it that way.
A Bosch relay is about $5. Basically, since your factory remote wire does not have enough current to turn on your amps, the relay will let you add more current to the wire and that should be able to turn on your amps. I'd go with the relay route rather than a switch, so everytime you turn on your radio, it will turn on the amps automatically.
Old Mar 11, 2001 | 08:02 PM
[VTEC]TL's Avatar
RWD convert
Post
Where can I get a Bosch relay?? And how would I install it???
AEM SRI w/ custom CAI conversion | Magnaflow axle-back quad exhaust w/ modded downpipe | Neuspeed Sport springs(modded: 3.5"F/3"R drop) | Acura OEM Wing | Mesh grill | "Euro" Headlight finishers | Graphics by GBM | Acura Indiglo Emblem | Mugen badging | Body color door handles | Polarg M-12's/Eurolite Hyper Blue's | Opti-Blue Xenon High beams | Hiper Strobes | 20%/35% Llumar tint | Razo RA42 Shiftknob | Alloy pedals | Dual 10" Blue neons in bumper | 2 JL10W subs | Boss CLR60 600 watt 4 ch. amp | Escort Passport 7500
Old Mar 12, 2001 | 01:40 AM
AcuraTL's Avatar
OG
Post
Any car audio/alarm install shop should be able to sell and tell you how to wire the relay.
It is very simple, I belive there are 5 terminals on the relay, you will only be using 4 of them. One is for power, one is for ground. One is for remote in and the other goes to the remote turn-on to your amp.
jpadilla
3G RLX (2013+)
Nov 18, 2017 07:13 PM
Skirmich
Sep 15, 2015 06:41 PM
Pegon95
Sep 15, 2015 01:54 PM
datadr
Sep 12, 2015 09:12 PM
