pulling a navi out
Old Mar 12, 2009 | 04:24 PM
thinhthan's Avatar
pulling a navi out
ok i got this guy that has two cars with the stock navi in it one is a 01 and the other one is a 02. he is giving me a steal on both the navi. the thing is i have to pull it out. what do i need to pull out and would i need anything extra to put it in my car?
Old Mar 12, 2009 | 04:29 PM
jjashaa's Avatar
Avant Garde Wheels
and all the wires that connect to it..
jjashaa's Avatar
Avant Garde Wheels
and if i were you.. i'd just trade the whole front dash too..
Old Mar 12, 2009 | 04:30 PM
jjashaa's Avatar
Avant Garde Wheels
Old Mar 12, 2009 | 07:02 PM
thinhthan's Avatar
if i pull all the wires that was connected to it would i need any other wiring to make it work in my 99?
Old Mar 12, 2009 | 08:10 PM
Superb's Avatar
should i spend more in
make sure u get the a/c controls located above the radio from the navi vehicle
Old Mar 12, 2009 | 08:39 PM
thinhthan's Avatar
yea i will
Old Mar 16, 2009 | 06:20 PM
thinhthan's Avatar
how will i know if i pulled all the wires i need out?
Old Mar 16, 2009 | 07:51 PM
01tl4tl's Avatar
what about the antenna?
No doubt you will need a new nav disc $185
Have you considered a TomTom gps?
Old Mar 16, 2009 | 08:40 PM
NSXNEXT's Avatar
It's not as simple as just pulling a couple of wires. The wires for the navi are part of a larger harness. You'll need to pull the wires out of the harness plugs. Make sure you remove the pins that go into the harness plug.
Old Mar 17, 2009 | 01:13 AM
thinhthan's Avatar
well cause im getting the navi for cheap and im installing it into a non navi.
Old Mar 17, 2009 | 05:57 AM
01tl4tl's Avatar
doesnt sound cheap!
several hours of labor pulling harness wires and cutting them open in order to run them again in your car....
Hoping you have the security code for the radio...
Old Mar 17, 2009 | 09:51 AM
c0v3rr1d3's Avatar
You need the security code for the navi too. At least right the vin down of the car u are pulling it from, acura can get the code based on the serial # on the dvd unit and the cars vin.
Old Mar 17, 2009 | 10:52 AM
juanclopez2786's Avatar
There's a guy on ebay that makes the harness for non navi to navi cars. He makes it all plug and play so its as simple as possible for u. Ill see if I can find him for u.
Old Mar 17, 2009 | 11:06 AM
Tommy99TL's Avatar
Tom
sell your and buy his whole car... that's look cheaper if he give you a "cheap" deal on his car too.
Old Mar 17, 2009 | 11:55 AM
thinhthan's Avatar
cause he is giving me the navi for 300. and whatever i need to pull out for it than i do that.
Old Mar 17, 2009 | 11:56 AM
thinhthan's Avatar
if you can find me that harness than i would really like that thanks.
Old Mar 17, 2009 | 12:51 PM
01tl4tl's Avatar
verify the radio and nav do work and work with their security codes before you pull anything out
- disconnect battery power and the codes will be required
That security code is critical to have,,
dont forget the newest release of the nav disc, or your house wont be on it~
Old Mar 17, 2009 | 12:57 PM
thinhthan's Avatar
i will
Old Mar 17, 2009 | 10:48 PM
send him a message on ebay HERE and ask about the harness for your car.
Old Mar 17, 2009 | 11:38 PM
thinhthan's Avatar
i think ima try to follow every wire and pull everything that it connects to
Old Mar 18, 2009 | 08:25 PM
thinhthan's Avatar
ok i pulled almost all the wiring in the dash when i pulled the dash and stuff out so i have most of the wiring
Old Mar 24, 2010 | 02:42 PM
wicked0377's Avatar
isn't it better to take the whole dash out and easier?
Old Mar 24, 2010 | 08:47 PM
LECKEY73's Avatar
I have the diagram if you need it. you seem to have all the parts now you have to do the labor.
Old Mar 28, 2010 | 02:46 PM
1StGenCL's Avatar
958 & 991
i installled a factory acura navi into a 1st Gen CL and it took some work but was really worth the outcome. Like the others have mentioned, you need the dash, a/c controls, screen, antenna, "brain" in trunk, dvd, trunk bracket, and the wiring. I can't imagine you get all the wiring so what I did was use pigtails that contained the plugs with a few inches of wire coming off. Then I went and bought shielded wire were needed and made my own harness. Lots of work but again, def worth it
Good luck
Old Mar 29, 2010 | 12:53 AM
dtownz_thrillah's Avatar
5th Gear
If its alot of work for you there are some NICE Pioneer double din navi units for sale for under $300 shipped brand new.
08KBP_VA
Oct 22, 2019 01:55 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
lanechanger
Oct 13, 2015 10:56 AM
Skirmich
Oct 1, 2015 12:59 PM
Cgannotti
Sep 25, 2015 05:04 PM
