project help
Old Nov 3, 2003 | 02:57 PM
BRCLS's Avatar
project help
I really need some help.
I want to do this...
Old Nov 3, 2003 | 04:42 PM
BRCLS's Avatar
damit stupid no edit message after30 min. went to add a whole page of text, tried to go back and I got erased
heres the pic
so this is what I want to do.
its a kicker solobaric S8l7
I have already removed the plastic locking pass trough.
I think I can make th box instead of paying 150 fo one.
keep in mind that I have a satelite radio attached to the back of the cd changer
I am confused on wich amp/speaker combo to get. 2 ohm or 4 ohm, do I get the S8l7 or the S8l5(the 5 has less features and I belive handles less watts) the l7 handles 900 watts but I think 300 is plenty.
I know I need a line output converter, but where does it start and where does it end.
I know that the speaker hooks to the amp but what does the
amp need to hook to? stock amp, rear speakers, head unit, ground?
I appreciate any advice thanks
Chad.
Old Nov 3, 2003 | 05:33 PM
Titand19's Avatar
East Coast Boost.!
just get a high lo. Hook it up to one of the rear speaker outputs, and you have the signal from the Rca cable to the amp.
The Ohms of the sub you get depends on the amp.
Old Nov 3, 2003 | 06:35 PM
RR32CLS's Avatar
"hey...wanna f^&k"
make sure you dont buy POS hi/lo converter. buy one that is adjustable and is up to like 30-40watts. peripheral or PAC are very decent.
Old Nov 3, 2003 | 07:27 PM
BRCLS's Avatar
what is a hi lo converter? what does it do,where does it go?
thanks
Old Nov 3, 2003 | 07:30 PM
RR32CLS's Avatar
"hey...wanna f^&k"
thanks
converts hi level speaker outputs to low level (sub) output. you need this part to connect rca cables to your aftermarket amplifier. you would connect the speaker hi level wires to the back of your 6x9 speaker wires.
Old Nov 3, 2003 | 08:32 PM
BRCLS's Avatar
so all I have to do is tap into the rear speakers using the converter and thats all. nothing else?
is this the line output converter I was talking about?
Old Nov 4, 2003 | 05:07 AM
phipark's Avatar
Not Asian
Get the l7. I don't know where you got 900 watts from, that must be the max. Follow the rms wattage. My 12l7 handles 750 rms. The resistance (ohms) depends on your amp as stated before. Get the dual 4 ohm if you want to run it at 2 or 8 ohms. Get the 2 ohm if you want to run it at 4 or 1 ohm. If you have an amp that can handle 2 ohms, get the dual 4 ohm sub. The lower the ohms, the more power your amp will provide.
Old Nov 4, 2003 | 06:18 AM
SilverKnight's Avatar
Retired. Not available.
This is the same setup on mine.
The sub is S8L7, rms wattage 450W.
You have to run it of an aftermarket one, no way to hook it to stock (I use JL 500/1).
The amp input can be from speaker wires via LOC (line out converter) or directly tapped (RCA cables) to the lines before stock amp.
http://silverknight.clickhere2.net/sound.html
Old Nov 4, 2003 | 02:01 PM
Titand19's Avatar
East Coast Boost.!
yo I missed the thread where you dissed the noon, can you open it back up.
Old Nov 4, 2003 | 10:13 PM
what are you gonna do?
Marcelechka
Home & Garden
188
Sep 11, 2022 11:53 AM
foxriderar77
Nov 19, 2020 10:17 AM
cycdaniel
Dec 17, 2019 10:58 AM
tsx_boy
Dec 13, 2019 08:33 PM
Sep 14, 2015 03:16 PM
