CL: Problem with voltage drop
Old May 18, 2009 | 06:41 PM
on1wheel01's Avatar
well first off I have a ho 160 amp alt and big 3 done. have 2 12" dc level 3's powered by a alphasonik pma1200da its been working fine for over a week with a aftermarket hu but the other day when hitting hard at anything below 1500 rpms it is cutting out bad and even when down a bit it sounds like the bass is sticking like your putting the rcas together a buzzing sort. my alt is like a month old and had the batt has been tested to be good it is a stock style I'm saving moneys for a better one. also sometimes the car is sluggish to start after hitting while driving but its only every now and then. I'm gonna have the alt tested and use a multi meter to see voltage drop. Ok thats just to get it started I bought a new batt 900ca's and 770 cca's. The problem was still there. So I put the old batt in the trunk. The problem is now gone. But I am wondering why it just now started. Didnt test the alt maybe I should but I figure it's fine being a month old. Now I guess I am gonna save up and get a kinetik or something for the back as I have heard it's not good to have normal batts in the trunk, is this true???
Old May 18, 2009 | 08:01 PM
D.Greenwood13's Avatar
2000 WDP
First off check your alternator just to make sure its still ok, and i recomend either 1 Kinetik HC2000 or 2 HC1400s for the amount of power your pushing. Personally i wouldnt put a normal batt in the trunk but some cars have em there factory and some caddys have em under the back seat
Old May 18, 2009 | 08:13 PM
on1wheel01's Avatar
Yea I think tomorrow I am gonna have the alt tested. I've gotta say the 2nd batt really increased the output.
Old May 18, 2009 | 08:21 PM
2000 WDP
Try the Kinetiks, u wont be disapointed!
Old May 18, 2009 | 08:47 PM
on1wheel01's Avatar
yea think i will im reading mixed reviews about having a batt in the trunk but many cars have em there from factory or under seats. Hell my 74 stingray had in right behind the pass seat but that was way back when
Old May 18, 2009 | 08:49 PM
mattastick's Avatar
While Kinetik's are sweet (I had one), I enjoy my Powermaster much more. The PM's are monster batteries. Another option (if you can afford it) is an NSB (Northstar Battery). Those things are absolute beasts. In case you're doubting, they are used in most (if not all) of the loudest street class competition cars on the continent. I would know, the defending North American Champ just kicked my ass this weekend... He did a 155.3 was his best run, Street A legal, and a 155.0 legal certified. That's impressive for 1 battery, car off, and 2 10's... There's one on ca.com, if interested, pm me.
Another thing to think about is 1/0 power and ground. If you already have this, do multiple runs of both. That's one of the best ways to keep your voltage up...
Old May 18, 2009 | 09:18 PM
on1wheel01's Avatar
yea I've been reading about those.. but moneys is kinda tight figured if go with what I can find cheap. found some kinetiks for around 100 used. I do wanna switch to 0 just need cash to do so
Old May 18, 2009 | 09:34 PM
mattastick's Avatar
Or you could just turn it down so you don't kill your gear... Then when you get the electrical to properly power your setup, then you can add power...
Old May 18, 2009 | 09:43 PM
on1wheel01's Avatar
eh can't keep it down lol if the amp frys then no biggie warranty but the subs would suck to fry. but I think going for a kinetik 1600 or so would work ok for now.
Old May 19, 2009 | 03:24 PM
on1wheel01's Avatar
well walmart took the batt back i was pretty surprised they gave me a full refund I found a used kinetik hc1400 for 100 im gonna try to get it for cheaper
Old May 19, 2009 | 03:27 PM
mattastick's Avatar
There's an NSB group 27 on ca.com for 185. I was going to get it, but I'm going a different route with my system now... It's like 10-12 pages back, but should be too hard to search and find. That, along with good 1/0 + and - wire should pretty well take care of your voltage problems...
Old May 19, 2009 | 03:30 PM
on1wheel01's Avatar
eh to much for right now. I figured that 1400 should take care of it wouldn't you think? Im pretty cheap right now to many things in the mix
Old May 19, 2009 | 03:36 PM
mattastick's Avatar
A 1400 might fix your problem, but I'd get on some 1/0 wire asap... The added/bigger batts are really just band-aids... If you run them for a long period of time, you're going to end up killing them, and then you're out money that could've been spent fixing what really needed to be fixed, instead of putting band-aids on it.
Old May 19, 2009 | 03:40 PM
on1wheel01's Avatar
yea I'm gonna get some 0 wire also think I'm gonna go with knu wire seems to be really good for the $$$$ after the 0 and kinetik all should be good I hope
Old May 19, 2009 | 03:42 PM
mattastick's Avatar
Yeah, it should be. While you're buying from Knu, I'd order extra. Get enough to do 1 run of + and 1 run of - from front to back. Since you seem to really like your bass, you might want to do multiple runs of each (if you can afford it) so you don't have to go back and re-do everything when you upgrade...
Old May 19, 2009 | 04:35 PM
on1wheel01's Avatar
im prolly gonna just get one kit of 17' and then it comes with like 5 for ground should be enough i hope. ill get more runs later on
may get this kit http://cgi.ebay.com/KnuKonceptz-com-KLM-Kable-1-0-Gauge-Amp-Kit_W0QQitemZ380124417252QQcmdZViewItemQQptZLH_Def aultDomain_0?hash=item58812e4ce4&_trksid=p3286.c0. m14&_trkparms=66%3A2|65%3A1|39%3A1|240%3A1318|301% 3A0|293%3A1|294%3A50
or i might try welding cable just have to find where to buy it first
Old May 19, 2009 | 04:53 PM
mattastick's Avatar
I wouldn't... Their KLM kable is a bottom of the line copper clad aluminum cable... Spend the extra money, do it right, and get multiple runs of Kolosus Flex...
Old May 19, 2009 | 05:00 PM
on1wheel01's Avatar
really i figured it was good as I've heard a lot of good stuff about it. Ah well maybe welding cable not sure on the price it is I've seen many heavy systems on ca.com with it. Keep in mind I get tired of stuff fast i will prolly eventually take everything out and sell it all and get focused back on bikes when my endorsement is reinstated but who knows maybe not so not wantin to break the bank but i dunno we shall see
Old May 19, 2009 | 05:36 PM
mattastick's Avatar
Here, get this: http://www.knukonceptz.com/productMa...0Fleks%20Kable
Take your choice of colors, and it's their best wire...
Old May 19, 2009 | 07:45 PM
on1wheel01's Avatar
yea i want it but man pricey
Old May 19, 2009 | 08:29 PM
mattastick's Avatar
Gotta pay to play buddy...
Old May 19, 2009 | 08:39 PM
on1wheel01's Avatar
true very true ah the guy wont budge past 90 for the hc1400 but still a good price since the 600's sell on ca.com for 70+ shipping used
Old Jun 7, 2009 | 12:42 PM
on1wheel01's Avatar
well i put the kinetik hc600 i have and took out the wet cell i had in the trunk. i gotta say it seems to hit harder. must be cuz they are designed to recharge and discharge faster. wonder what it would be like with more of em in
mada51589
Jan 9, 2025 04:40 PM
heykosal
1G RDX DIY & FAQ
Nov 16, 2020 03:59 PM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
HeloDown
Sep 8, 2015 06:51 PM
