Problem with sub..
Old Jan 22, 2002 | 09:51 PM
hornyleprechaun's Avatar
Bent = #1
Problem with sub..
I have 4 10" Sony Xplod subs..and I was rehooking them up today..all 4 worked perfectly fine when i unhooked them...and now 1 of them doesnt' work...i feel it vibrate a little bit..meaning there is power going into the sub?? well the other 3 subs hit fine..just like normal...but this sub won't hit at all...any ideas??
CL'S
Old Jan 22, 2002 | 10:17 PM
CLUofI's Avatar
337
unhooked wiring inside the box while you were moving it around.
Old Jan 22, 2002 | 10:29 PM
Woodsdaddy's Avatar
Everybody Wang Chung
Are they all in their own chamber? If one is out of phase then it will not move but the others will because there are more of them. It would sound like you only have two because two of them are cancelling eachother out. So check your wiring and make sure everything matches up.
Old Jan 22, 2002 | 10:52 PM
Bent = #1
Yea I thought that the wiring inside the chamber was unhooked...i'm checking that tomorrow...yes each sub has its own chamber..own channel from amp..own wires from amp...
CL'S
Old Jan 22, 2002 | 11:39 PM
Eggplant-EX's Avatar
hornyleprechaun : are you sure you have enough subs in the back????? LOL
Old Jan 23, 2002 | 05:53 PM
Bent = #1
NEVER!!! heh..i honestly want to add 2 more subs...but I want to add some other stuff to my car first...
CL'S
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
