Problem with sub..
Old 01-22-2002 | 10:51 PM
hornyleprechaun's Avatar
Bent = #1
Problem with sub..
I have 4 10" Sony Xplod subs..and I was rehooking them up today..all 4 worked perfectly fine when i unhooked them...and now 1 of them doesnt' work...i feel it vibrate a little bit..meaning there is power going into the sub?? well the other 3 subs hit fine..just like normal...but this sub won't hit at all...any ideas??
CL'S
Old 01-22-2002 | 11:17 PM
CLUofI's Avatar
337
unhooked wiring inside the box while you were moving it around.
Old 01-22-2002 | 11:29 PM
Woodsdaddy's Avatar
Everybody Wang Chung
Are they all in their own chamber? If one is out of phase then it will not move but the others will because there are more of them. It would sound like you only have two because two of them are cancelling eachother out. So check your wiring and make sure everything matches up.
Old 01-22-2002 | 11:52 PM
Bent = #1
Yea I thought that the wiring inside the chamber was unhooked...i'm checking that tomorrow...yes each sub has its own chamber..own channel from amp..own wires from amp...
CL'S
Old 01-23-2002 | 12:39 AM
Eggplant-EX's Avatar
hornyleprechaun : are you sure you have enough subs in the back????? LOL
Old 01-23-2002 | 06:53 PM
Bent = #1
NEVER!!! heh..i honestly want to add 2 more subs...but I want to add some other stuff to my car first...
CL'S
SidhuSaaB
05-30-2020 01:40 AM
Fool
03-10-2016 09:42 PM
12vancover
10-16-2015 01:04 PM
Matthew Purpura
09-25-2015 07:10 PM
MikeJM310
09-24-2015 08:24 PM
