Powered up my sub and all I hear is bass!
Old 11-25-2005 | 11:49 PM
jd33's Avatar
I just wired in my sub and amp, and as soon as I switched the ignition on, I got nothin but bass... even with the head unit off.
Any ideas/help would be much appreciated.
Old 11-26-2005 | 01:05 AM
dark inspire's Avatar
El Presidente
which car do you have, and how did you wire it?
Old 11-26-2005 | 02:34 AM
jd33's Avatar
'05 TSX, Amp is tapped off the two rear 6x9's through an LOC, Remote On from +12 signal in center console, Grounded beside spare tire. I know the amp is wired correctly to the sub because it worked fine in my last car. All I did was hook up power, ground, and remote on.
Old 11-26-2005 | 04:36 AM
Tsx536's Avatar
Rep'n Taxbrain.com
Since you wired the Remote On input of the amp to the +12v signal in the center console, you're amp is gonna turn on whenever you turn the ignition on. The center console power outlet gets +12v whenever the ignition is on regardless of whether or not your stereo is on.
You need to rewire the amp remote on input to the same remote turn on wire that goes to the factory amp. This can be found on the 20 pin harness that plugs into the factory amp. Check the TSX Faq section mang
Old 11-26-2005 | 10:19 AM
KaMLuNg's Avatar
same thing happened to me... u need to lower the signal from the LOC... the two little screws inside the LOC...
Old 11-26-2005 | 11:13 AM
jd33's Avatar
Thanks guys, I'll try that.
Old 11-26-2005 | 02:46 PM
jd33's Avatar
Sweeeeet ... that was the problem, had the left and right output turned up too high. Weird though, because now I can't repeat that problem ... oh well ... I'm rollin with bass now.
Bit of a rookie on the audio install, but I'm sure glad I did it myself - learned a lot, had fun, and all thanks to this forum .
peace
Old 11-26-2005 | 08:40 PM
KaMLuNg's Avatar
peace
when u tried to reproduce the problem was the car on??? try that... when i was figuring it out i was like WTF... seemed like there was an exhaust leak into my sub... glad i could help...
Acura604
20
08-05-2017 12:55 AM
spudweb
05-22-2016 02:39 PM
merc009
09-29-2015 03:06 PM
95oRANGEcRUSH
09-25-2015 12:50 PM
4drviper
09-23-2015 09:00 PM
Quick Reply: Powered up my sub and all I hear is bass!
