Power source in TSX trunk?
Old Jun 5, 2006 | 02:02 PM
Masterpoolcat's Avatar
Where is a good 12v power source in the trunk of a 2004 TSX? Or if anybody has the wiring diagram for the trunk? I need it to power Dom's nav converter and an amplified antenna. Any help will greatly be appreciated. Thanks.
Old Jun 6, 2006 | 12:39 PM
StanMan's Avatar
i would find an unused slot in the inside fusebox and run a sufficiently thick gauge of wire along the sill to the trunk for power. easier, no diagrams nor tools needed except for a circuit tester and you're not tapping onto something else!
don't you need a switched/ignition lead as well???
Old Jun 6, 2006 | 01:38 PM
Reach's Avatar
Yes, you need a switched source. It really would do you well to run a switched wire from a cig lighter to the trunk. You'll also find it useful for 'future' upgrades.
Old Jun 6, 2006 | 08:32 PM
Thanks guys, but I just ended up tapping into the yellow/red wire in the back of the navigation unit. This is a switched 12v wire.
Old Jun 6, 2006 | 08:53 PM
vidgamer's Avatar
I was looking to tap the front cig lighter for a couple of things -- what do you do, pull up the center console around the shifter, remove the "not an ashtray", then splice into the wire near the plug? (That's what I'm planning as soon as I buy some crimp splicing thingies.) I hate removing that center piece...
I was also toying with the idea of adding some additional blue LED lighting... what would be good to tap into? There's a small light at the top of the other pocket... I imagine you can't draw too much from that circuit, but I hope a few LEDs are OK. :-) (I'm still not sure I want to go ahead with this. It'd be nice to have a switch because it might get a bit old...)
Old Jun 8, 2006 | 11:13 PM
You got it! You also need to remove the compartment above the "not an ashtray" in order to remove the screws that hold in the "not an ashtray". Or if you want, you could just remove the center console. There are 2 wires for the cig lighter plug in the center compartment (White w/ Red stripe and Black). This way you would not have to remove the other 2 pieces. Here's a picture:
Old Jun 10, 2006 | 12:16 PM
vidgamer's Avatar
In a couple of other threads, there's a photo of a "tap a fuse" type connector, where you can add a fuse and draw power from the fuse box. That might be a better way to do it, if you can find a power source that is switched at the same point that you want it. I may try that first, as it sounds like a cleaner solution. I'm sure I can find something that is switched on with the car, and hopefully there's something that switches on with the lights as well. (Of course, running the wire across under the dash, I'll make sure it is out of the way and secure.)
Feb 25, 2020 09:57 AM
VA2000TL
Oct 2, 2015 08:26 AM
Sep 17, 2015 10:16 AM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
datadr
Sep 2, 2015 06:46 PM
