power for Dom's unit? (2006 tsx)
Old Oct 27, 2007 | 09:56 AM
smazzurco's Avatar
I searched and everyone says they "got power from the back of the nav unit in the trunk" but no one says what wires those are....any help?
Old Oct 27, 2007 | 10:48 AM
Reach's Avatar
Get a manual! There's a power wire on the small harness. (Or you could check for it with a multimeter.)
Old Oct 29, 2007 | 12:35 AM
csmeance's Avatar
I would not even attempt to get power from the navi unit, any failure to the navi unit will be blamed on the power wire and the drive is in excess of 2k. I would just run an add-a-circuit from the fuse box with a new wire to doms unit, or tap the cigerate lighter.
Old Oct 29, 2007 | 01:11 AM
vthree's Avatar
2006 ASM tsx
i believe on the 06s u donte ven need a doms unit=X
Old Oct 29, 2007 | 10:25 AM
Reach's Avatar
you do if you want to run a video signal, ie: xbox. you don't need a dom's if all you want to do is use a backup cam.
Feb 25, 2020 09:57 AM
Sep 15, 2015 06:44 PM
ivegotthenav
Sep 11, 2015 07:51 PM
