Pioneer AVH-7480DVD Question
Old Feb 2, 2003 | 10:16 AM
LSonDubz's Avatar
Is there a way to get the screen to stay open after the car is shut off? I need it to stay open for when I attend shows but for the life of me, can't figure out how to get it to do so. The instruction manual hasn't been much help either.
Also, how can I get this unit to play actual TV? What do I need?
Old Feb 2, 2003 | 04:33 PM
shawhite's Avatar
yep there sure is... if i remember correctly you would hold down the menu button on the screen for 2 seconds and then a menu will apear press the -/+ buttons to scroll thru and you should see a menu that says auto open... turn it off and there you go... and in order to play tv you will need a tv tuner...
Old Feb 2, 2003 | 05:57 PM
LSonDubz's Avatar
hmmm i've been to the menu a million times havn't seen anything like that, as far as the tv tuner i guess i was mistaken when i thought this unit had a built in tv tuner.. it said super tuner, so i assumed tv.. my bad... any idea where i can pic up a tv tuner cheap and which one i will need?
Old Feb 3, 2003 | 06:16 AM
shawhite's Avatar
the cheapest pioneer tv tuner i have seen would be at www.etronics.com ... as for the menu there is 3 different menus.. the gui menu when the unit is on, the gui menu to set the time, plate color and etc (this is done while the unit is off, simply hold down the menu key on the remote for 2 seconds) and then the 3rd menu has the screen color adjustments, auto open... etc.. (this is done by holding the menu button on the screen itself for 2 seconds while the unit is one) there should be a red and white colored menu appear at the bottom of the screen... and the super tuner refers to the am/fm tuner....
Old Feb 3, 2003 | 05:05 PM
LSonDubz's Avatar
Winds up you have to hold the "wide" butto non the unit.
BTW, do you know if it is possible to have the graphics and all show while playing a CD? On mine, all I get is a blue screen which pretty much sucks. Thanks
Old Feb 4, 2003 | 05:57 AM
shawhite's Avatar
no it is not possible unless you have an external cd source... ie cd changer...
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
Eggs999bacon
Sep 24, 2015 10:08 AM
