Peak Wattage vs. RMS
I forget what the conversion is for Peak vs RMS Power. My Speakers are the MB Quart Q Series Components. Handling Power of 90-170 Watts. What is the power I would need to handle these in RMS Wattage.
NJ_CLS_driver:
Peak is just RMS*sqrrt(2)...so you would divide peak by the square root of 2, ~.707, to get RMS. But a lot of speaker manufacturers don't go by this rule...a lot of the RMS and peak values are quite arbitrary...but that's the actual conversion.
Austin519
Austin519
Austin, thanks. The reason I was asking, was that I bought the MB Quart QM218.61 Q Series Compontents for the front, and they are rated as 90-170 Watts. No RMS
Hey Austin519: Isn't the conversion multiply instead of divide? Because RMS is always lower than peak. And by dividing it, then the RMS would be greater than peak, which it really isn't.
Originally posted by Austin519
chizad1980:
Nope. The sqrrt(2) is 1.41. So Peak/sqrrt(2) = Peak*.707 = RMS, as I said. The sqrrt(2) > 1.
Austin519
chizad1980:
Austin519
chizad1980:
My entire statement was correct. The statement I just made that you're agreeing with is the exact same statement as I said first. I believe you just read it incorrectly.
Austin519
Austin519
chizad1980:
"Peak is just RMS*sqrrt(2)...so you would (1)divide peak by the square root of 2,(2) ~.707, to get RMS."
(1) = divide by the square root of 2 = 1/sqrrt(2) ~ .707 = (2)
Now please stop wasting my time by having me come back to this post thinking that someone asked a Q when it's just you being annoying...
Austin519
Austin519
I know what RMS is! I was just saying that your very first statement was partially incorrect. I am talking about this: 2,(2) ~.707 The ~ means "about" right. Well, what does the other stuff you posted refer to? Because dividing peak by the square root of 2 is correct, you say that, but you also say it is ~.707, which it is not!
chizad1980:
"Well, what does the other stuff you posted refer to? Because dividing peak by the square root of 2 is correct, you say that, but you also say it is ~.707, which it is not!"
1/sqrrt(2) ~.707
I've removed my subscription to this thread...so if that didn't clear up what you miscontrued I guess it's a lost cause.
Austin519
1/sqrrt(2) ~.707
Austin519
09-17-2015 09:01 PM
