optima yellow top
Old May 13, 2005 | 06:35 AM
NICKTL's Avatar
optima yellow top
my dash flickers when the bass hits. was wondering if i get the optima yellow top will it prevent this? if so anyplace cheap? also the model #? i have a 2002 TL-S. thanks
Old May 13, 2005 | 07:26 AM
optomos's Avatar
I=X - optomos
How many amps you running. Look on cardomain or check out autozone & pepboys. 51RD or D34/78. Not sure bout the D34 but you want at least 800A.
Old May 13, 2005 | 07:40 AM
NICKTL's Avatar
as of now just one JL 500/1 pushing a JL 12w6 v2
Old May 13, 2005 | 08:31 AM
car_lost's Avatar
i have a 500watt amp as well and my dash lights would dim ever so slightly when the bass would hit. after i got the yellow top, it didnt do it anymore.
Old May 13, 2005 | 08:35 AM
dark inspire's Avatar
El Presidente
interesting, ive got a 500/1 to a 10W6v2, no problems for me...
Old May 13, 2005 | 09:01 AM
elduderino's Avatar
VP Electricity
I tend to wonder about the battery you have... have you load-tested it?
I like Optima Yellow-tops, but I don't think that switching from a healthy battery to one would solve that problem...
Old May 13, 2005 | 09:07 AM
car_lost's Avatar
when i had the stock battery, i put the sysyem in. when the car would sit in idle and the bass would hit, the gauges only (not the headlight or anything else) would dim a little bit. it was hardly noticeable, but if you looked hard enough, you could tell.
the battery died 6 months later. so my problem could have been due to a weak battery.
what i know is that ever since i put in the yellow top... about 6 months ago, it's been absolutely fine. i even had an indash TV installed (not sure if this draw's more power or not than a stock radio) and everything is still perfectly fine.
Old May 13, 2005 | 10:08 AM
elduderino's Avatar
VP Electricity
Don't get me wrong, I think it's a great upgrade, and I have one in my Honda CR-V. I just think that a lot of problems are like what you stated - a weak OEM battery at the end of its useful life - and the Yellow tops and Exides last a lot longer in those conditions.
Old May 13, 2005 | 10:11 AM
phipark's Avatar
Not Asian
It sounds like your battery is on it's last legs.
Old May 13, 2005 | 10:18 AM
NICKTL's Avatar
yeah same thing with my car. just the dash dims a bit, the headlights are fine. i just want to reslove this before i strain my alternator. does anyone know the correct model number for a 2002 TL-S yellow top optima battery?
Old May 14, 2005 | 02:26 AM
ou sig's Avatar
Boomer SOONER
ya your battery is bad - the yellow top will only help with your car off because of its deep cycle capabilities but it wont help much vs. a good regular battery because you dont have enough power drain. I have 1100+ watts RMS with the stock alternator and a good battery and everything is fine.
Old May 17, 2005 | 05:28 PM
Blackwidow's Avatar
Get one
'sup?
yeah, i had a stock battery in before i got a yellow optima and it made a world of difference (the stock one probably sucked to begin with anyways).
I have a Pioneer Class-D 1000 watt amp, 2 pioneer 12's with a dvd/navi/rearcam
and when i was playing my dvd's/audio before my old batt just couldn't handle her. Now with the optima, i don't have any problems at all. go to pepboys, they'll give you 5-10 bucks if you switch out your battery in the parking lot and bring it in. Just make sure to bring your own tools.
Old May 17, 2005 | 06:30 PM
palidanx's Avatar
honk not beep
hey does anyone know if the yellow-top batteries at costco are actually rebranded optima ones?
hashbrown
Feb 18, 2022 11:20 AM
Acura604
20
Aug 5, 2017 12:55 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
jmaxima03
Sep 27, 2015 10:22 AM
