Ohms
Old Apr 14, 2004 | 12:16 PM
Acura2.3CL's Avatar
Ohms
My friend is getting 2 subs that each are 4 ohms. They are 350watt max power so he was thinking about getting 1 1200watt, 2 channel amp to push them. Will this work well? What ohm will the amp need to be? Thanks!!
Old Apr 14, 2004 | 08:18 PM
Hobo's Avatar
Flap.
well it depends on how your friend chooses to wire the subs... figure out how the wiring will be done then match the rms of the subs with the rms power of an amp when run at the impedence that your friend decides to wore the subs to..
Old Apr 17, 2004 | 04:43 PM
Acura2.3CL's Avatar
thanks!
Old Apr 17, 2004 | 10:19 PM
AcurajL's Avatar
I hand out swivel heads
way too much power... and the amp should run at ar 2 ohms
Old Apr 18, 2004 | 10:47 AM
Hobo's Avatar
Flap.
well he could run it at 8 ohms, or something in between using series-paralell wiring, assuming they are DVC subs... as i said, all depends
Jul 16, 2017 07:33 AM
jamestheunderdog
Jul 19, 2016 07:58 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
Medinak12
Sep 23, 2015 07:11 PM
