MISC: Noob Amp Question
Old Feb 28, 2011 | 05:42 PM
Flipster23's Avatar
Noob Amp Question
Fourthmeal,trunk monkey, eggyhustles, mattastick where are you guys help me LOL! hope I spelled your names right
Picking up an RE audio 10" sub this Friday from a member on car audio forum and want to know what amp should I run. Not to sure how many watts I should get. Last time I bought a amp and hooked it up to my subs I blew my subs. Subs where 500 Watts RMS each and my amp was 1000 so I dont see why it would have blown, but I am a noob to some aspects of car audio including this one. LOL
Here is the sub I am getting
WoofersEtc.com - RE10 - RE Audio 10" 250 Watt Dual 4 Ohm RE Series Subwoofer
Please let me know what is the correct amp wattage I should be running for one of these.
Old Mar 1, 2011 | 12:00 PM
on1wheel01's Avatar
sundown saz1500d and be done with it lol. But I love sundown amps.
Always set your gains with a dmm if u dont have a o scope
Old Mar 1, 2011 | 12:06 PM
Flipster23's Avatar
I got the amp info now from Caraudioforum...
No I'm going to attempt to make my own enclosure something I always wanted to do my friend works in Lumber @ Lowe's and I have a new sub so I think its a good time to do it..
Just need to get the specs from the sub to build the enclosure
Old Mar 1, 2011 | 12:45 PM
eggyhustles's Avatar
It's overkill for his setup, but he'll never have to purchase an amp again. If you have the coin for it, get it.
Wire the sub up to 8 ohms. Should give you 200w
Old Mar 1, 2011 | 12:56 PM
Flipster23's Avatar
Not really trying to spend hella on an amp I have a wedding in october LOL on a slight budget for right now
Old Mar 1, 2011 | 04:30 PM
on1wheel01's Avatar
Over kill yes but set the gains correctly. And as you said that amps good for so many applications. They run about 300 shipped used from ca.com or caco
Old Mar 1, 2011 | 04:39 PM
Flipster23's Avatar
another noob question
is there a program or maybe a site where I can design my enclosure because I cannot draw for shit!
Old Mar 1, 2011 | 04:49 PM
fourthmeal's Avatar
Google sketchup! Its all I use. Then of course winisd pro to design the enclosure specs.
Literally what i do is fire up GS, then WinISD, and run them at the same time. I model up my ideal box size in winisd, then I start sketching a box that will get that spec to work. If I find that my box is unreasonable, then I go back to winisd and see where any adjustment can be made to the airspace or tune (if ported), and flip-flop back and forth until I find a balance.
Results as an example:
Old Mar 1, 2011 | 04:54 PM
Flipster23's Avatar
thanks!
Old Mar 2, 2011 | 09:53 AM
mattastick's Avatar
OP, what's your budget for the amp? With that sub, you really only need a couple hundred watts. Then again, if you have the cash in your budget for an SAZ-1500D, please save yourself the hastle and get one. They're great amps, and like eggy said, you'll never need to buy another amp. I regreted selling my previous 2 so much I bought another.
Old Mar 2, 2011 | 12:53 PM
fourthmeal's Avatar
SS DTR amps are cheap as hell right now, and very, very powerful. Pick your poison.
Old Mar 2, 2011 | 12:55 PM
Flipster23's Avatar
^ from where?
Old Mar 2, 2011 | 02:42 PM
fourthmeal's Avatar
Well for one example woofersetc.com has the 1.1700 for $230, and the 1.1400 for $190.
But on ebay you might be able to do even better. They definitely do rated power.
Old Mar 2, 2011 | 02:58 PM
Flipster23's Avatar
I'll look into it Thanks!
4drviper
Apr 23, 2025 07:13 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
Rcelestino93
Sep 23, 2015 10:01 PM
