nneed help finding right amp!
Old Jun 12, 2008 | 02:17 PM
italiaCLs's Avatar
9.5 lbs o' Boost!!!!
Hey guys, I am a total audio newb! and need some help. I have this kicken new custom enclosure with a box that houses 2 12'' subs. I have to go with JL audio because there are plexi glass peices that say JL audio in the essemblly. I am getting these subs.
2 JL Audio 12W1V2-4 Subwoofers NEW 05 12" SUBS NEW PAIR
but i am trying to find the proper JL amp!!!any recommendations!
I don't know what im looking for. any suggestions would help, I need a direction to steer in.
Old Jun 13, 2008 | 01:30 AM
wong05tsx's Avatar
Need more room in
I have the perfect amp for you!
https://acurazine.com/forums/car-parts-sale-361/fs-sundown-audio-sax-100-2-amp-393043/
The W1's are single voice coil.
You can either wire them in parrallel to achieve a 2 ohm load, or wire them individually into a 2 channel amp, seeing a 4ohm load each.
If you wire them individually to a channel to the sundown amp, they'll see ~150-175w per channel since the amp is underrated, should be perfect!
Old Jun 13, 2008 | 12:57 PM
italiaCLs's Avatar
is it a JL amp?
Old Jun 19, 2008 | 05:09 AM
konneezy's Avatar
i don't know a lot about audio but this is what i've heard.
your SUB power or Watts should match(or be close to) the power of your AMP
so if you have a 500 watt sub you should be looking for an amp that produces approximately 500 watts
you can damage the sub if you have a amp that produces to much power, The cone of the speaker and the mechanical parts that make it move may break under the stress, and if you don't have enough, damage occurs more often from under powering.
also you should judge your subs power by its rms rating not its Peak Power wattage.
hope this helps
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
gatrhumpy
19
Dec 31, 2015 04:22 PM
BIGxRED
Oct 19, 2015 10:47 PM
