new headunit but buzzing noise
Old 04-19-2009 | 11:06 PM
dlin005's Avatar
i just got my stock radio replaced with an aftermarket pioneer head unit and i have 2 12 sub's in the trunk.. but when i turn my car on and listen to the radio.. there is a buzzing sound. the guys at fry's told me to get A/C sound filters for my radio and i did.. but i still hear the buzzing noise. anybody know what i can do to fix this?
i have stock speakers.
Old 04-19-2009 | 11:30 PM
nf3d0149ab's Avatar
I saw your other post in the CL forums.
Glad you found this Audio & Video forum.
Hopefully someone can help you out.
Old 04-19-2009 | 11:41 PM
dlin005's Avatar
yeah i have an 01 CL TYPE S and... its not cool
Old 04-19-2009 | 11:45 PM
nf3d0149ab's Avatar
Never heard of this issue.
Does the buzz...go up and down with the volume?
Old 04-20-2009 | 10:54 AM
dlin005's Avatar
no the buzz is just constant.. its really inbetween songs is when i hear it the most or when my volume is really low
Old 04-20-2009 | 11:29 AM
Jonesi's Avatar
who installed your system? I'd take it back to them it's definitely a install related issue.
Old 04-20-2009 | 12:42 PM
dlin005's Avatar
frys installed it. i think it has something to do with my stock bose amp. but im not sure my old accord never had such a complicated installation
Old 04-20-2009 | 01:57 PM
Reach's Avatar
If they didn't have your battery disconnected when they installed the harness and speaker lines, they may have popped a micro fuse on the pioneer's board. They hosed your install and the only fix is to replace the micro fuse (which most people aren't up to) which means a new HU.
Much more info on buzzing Pioneers over on the12volt.
Its next to impossible to diagnose this over the internet, but I'm not feeling good about your install.
Old 04-20-2009 | 02:06 PM
nf3d0149ab's Avatar
Damn...that sounds like a shitty problem to deal with...
And I agree with the moderators that it's going to be difficult to diagnose over the web.
Good luck dlin005
Old 04-20-2009 | 02:56 PM
mattastick's Avatar
Reach, another way to "fix" the buzzing caused by a blown pico fuse is to ground the RCA's to the chassis of the hu. From what I've heard, this is the best alternative if you don't have the means/cash to replace the entire hu...
Old 04-20-2009 | 06:22 PM
Jonesi's Avatar
It's not a complicated install unless you replaced all your speakers also.. It's actually a easy install with the right harness..
Old 04-23-2009 | 06:10 PM
rtls02's Avatar
i think its a rca problem
Old 04-23-2009 | 08:24 PM
on1wheel01's Avatar
could it be the factory speaker wire problem? that stuff is thin as crap i just got done running 14 gauge to my doors.
Old 04-23-2009 | 08:35 PM
mattastick's Avatar
I like this idea...
Old 04-28-2009 | 12:28 AM
simply_Corrupt's Avatar
Hi I don't know if this would help but i just replaced my headunit and installed a sub in my 01 CL-S, running stock speakers. What i found was that when it was running off the stock amp the sound wasn't so clear and was a slight buzzing. I ended up removing the harness from the stock amp and splicing the wires bypassing the amp altogether (running speakers off deck power). This cleared up the sound and the buzzing.
Cheers
Old 04-30-2009 | 11:15 PM
srtorelli's Avatar
Honda Nation
Having the same problem with my pioneer d3 aswell. What it is is engine noise. Happens when you hook up your front end to an amp. You need to ground the rca's and speaker wire behind the deck. When you drive you can litterly listen to your alternator winding up and down.
MrHeeltoe
20
02-23-2023 01:54 PM
SexyRL
4G TL Problems & Fixes
08-19-2016 10:03 PM
xsilverhawkx
10-05-2015 11:00 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: new headunit but buzzing noise
