Neon Footwell Install
Old Jul 18, 2003 | 05:55 PM
Yaron2's Avatar
I want to put in two neon footwell lights in the car underneath the dash.
Please tell me how to do the following that someone else did but whose e-mail is no longer active to respond to my questions:
OR if you can direct me to detailed install instructions with pics (if possible)
"I wired them together, connecting the +12v to constant power and connect the ground of the lights to a SPDT switch. One terminal of the switch I connected to ground. One terminal I connected to the door trigger wire (located in the passenger fuse box) going through a diode first. This arrangment allows the lights to come on whenever a door is opened and when the car is first disarmed, just like the domelight. I can also flip the switch and leave them on permanently, like while cruizin. Or I can leave the switch in the middle position and have the lights disabled."
Thanks in advance (I know this one is tough to explain)
Old Jul 19, 2003 | 07:09 PM
SilverKnight's Avatar
Retired. Not available.
I'll get you some pics by tomorrow nite and I'll show you how to deal with the problem you have with the DC/AC power converter too.
Old Jul 21, 2003 | 07:08 AM
Yaron2's Avatar
Silvernight ..... could you post all of the info that you have on the lighting and PM me the solution to the DC/AC problem.
Thanks!
Old Jul 21, 2003 | 11:42 AM
I didnt have a chance to take the pics.
Anyway, for you DC/AC problem, you will need a SPST relay. Wire the relay so that the ignition wire will trigger the switch to the DC/AC coverter's power supply. That way your converter will be isolated when the engine is off.
cycdaniel
Dec 17, 2019 10:58 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
pistacio
Sep 26, 2015 09:45 AM
TxRzrBk
Sep 17, 2015 01:07 PM
