Need ideas on where to mount my Clifford alarm LED
Received 1,080 Likes
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
I am having fogs put in, and I needed to move the alarm LED and valet switch from the blank where the fog switch goes. Moved the valet switch but now...
I need to find a cool place to mount my alarm LED. Thought about wiring it into the factory alarm LED, but I really want people to know I have an alarm, and I figure that wouldn't do it.
I thought mayve putting it behind the clear plastic cover that goes over the map lights.
Or maybe behind the rear view mirror. There appears to be a hole to put it in.
Anyone....
1999 Satin Silver Metallic 3.2 TL w/o Navigation
Anyone....
- 18x8 Racing Hart C2s with 225/40ZR18 Dunlop SP Sport 9000
- Comptech Springs, Sways, Exhaust, and Headers
- NEUSPEED Front Upper Strut Tie-Bar
- Red AEM CAI w/bypass valve
- A'PEXi Digital VTEC AFC
- Denso Iridium Plugs
- Custom Mugen Grill
- Inspire Tail Lights
- Factory Underbody Kit and Spoiler
- Clifford Intelliguard 9000 Alarm w/SmartWindows II
- Alpine 6 disk CD Changer
- BEL 945i Cordless Radar Detector
- Burlwood Shift Knob & Trunk Tray
- 20% tint
![Post](https://acurazine.com/forums/images/icons/icon1.gif)
I have a Viper alarm, and I opted instead of using the small alarm LED, I got a DEI scanner that I put at the corner of the windshield on the drivers side. It has the red light that flashes from left to right (kinda like Knight Rider), and it is very bright and can be seen from any side of the car. I really like it for two reasons, one is that you don't have to drill a hole like you do for the regular LED, and because it is much more noticeable than your standard alarm LED light, IMO.
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by swhtech on May 23, 2001 @ ]</font>
put it on the rear view like the bmws.
thats where i mounted it on my toyota. only downside...people will notice it, so if you forget to arm your car, the whole block will notice and know when to break in. someone pointed that out to me a while ago
Follow as i ride
99 Satin Silver
oem kit
ctech exhaust
ctech sways
aem intake
system
Follow as i ride
99 Satin Silver
oem kit
ctech exhaust
ctech sways
aem intake
system
I had a Clifford 900IQ in my Integra and mounted the LED about 2" up from the base of the plastic trim on the driver's side A-pillar. Not a terribly "cool" place for it, but I could see it readily... to make sure I entered the right BlackJax code ![](http://www.acura-tl.com/ubb/smile.gif)
2000 WDP 3.2TL non-NAV
AEM CAI w/bypass, Comptech header
![Talking](https://acurazine.com/forums/images/icons/icon10.gif)
Behind the mirror is a good spot. Or maybe way up on the center dash near the windwhield? And those "chasing" LEDs are pretty cool? Where did you put your valet switch? (mine's on the small blank next to the dash dimmer).
I had 2 super-bright Varad blue LEDs put in the plastic triangles inside of the mirrors when my Clifford was installed. It's pretty easy and you could do something like that? Check it out!
Sticky Rice OwnZ joO
1 Post
We gotta add this to the list of cool "How to" things like the LED Jake did. Once you get some instructions that is.. ![](http://www.acura-tl.com/ubb/biggrin.gif)
Even just replacing or adding LEDs to the wiring would be a nice help.
BTW, my valet switch is in the same place as yours.
Where did they mount your motion sensor, the square thing that says Clifford?
Mine is underneath the trip reset buttons.
One sensor is in the center console in that depression between the seat heater buttons. I have it attached with a some velcro to the little door where the diagnostics plug is behind. There is also another Omni sensor under the hood behind the strut bar on the firewall.
Hey Neil - where did they put the actual alarm module. Mine is in the kick panel back under the hood release. They also installed the small, round "eye" for the remote (looks like a small microphone) right there at the top of that kick panel. Where's yours?. I'm thinking about moving mine somewhere higher in the car to increase my remote's range. What do you think is a good spot?
They did a pretty sh!tty job installing my alarm. It was very cheap however.
My alarm brain is under the panel near your knees. The round eye thing I'll have to look for. You're not talking about the light sensor are you?
I'm thinking about having the guy that's doing my fog lights, move my alarm horn to a better spot. The idiots mounted it on the strut bar. I think it should be hidden a little better.
There is a extended range module, it looks like one of the motion sensors. I think that affects the remote range.
No - the day/night sensor is on the dash at the bottom of the A pillar on driver's side.
Is that extended range module extra or do I already have it? The owner's manual is good as far as programming and features but it doesn't give you schematics or specs. I need more info on that unit.....
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by TL Daddy on May 24, 2001 @ ]</font>
sockr1
10-01-2015 01:31 AM
2015TLX
09-11-2015 02:56 PM
