need help tapping into speaker wiring
Can anyone help me on finding the easiest way to tap into the factory speaker wiring without splicing the adater on the back of the headunit, so i can run my speakers wire from my amp to it.
If this is for a sub in the back, remove the back seat...locate the wires on the passanger side. Tap the 2 wires inside the brown cover. It's a mono line..so one is positive, one is negative. The orange wire is the remote wire...mine only gives +5V tho, which isn't enough to kick the amp on.
Most people also recommend yanking the plug out of the stock amp if you add your own subs.
Acura604
20
Aug 5, 2017 12:55 AM
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
