Need help re-wiring!
All right guys, here is the story:
After getting the car, i decided i needed more bass. I got a mtx amp and 2 JL-10W3. The problem is, the place did a serious "ghetto-rig" for EVERYTHING.
Now, I kept the subs and upgraded to a JL 500/1 amp. The guys that did the original install used very thin wires, i think 12guage. Now i am hooking everything up with 4gauge Monster wire (the right way). I have pulled the power wire through (very difficult) and now need to find a ground. The clamp is huge and I need to find where to ground it.
WHERE CAN I GROUND IT IN THE TRUNK WITHOUT DRILLING ANY NEW HOLES?? Also, what and where do I hook the remote wire to??
Retired. Not available.
Re: Need help re-wiring!
Re: Re: Need help re-wiring!
Originally posted by SilverKnight
take a look at the sound template in my sig.
Re: Re: Re: Need help re-wiring!
Alright, you say you screwed it down at the trunk access. following your pics, i went to the trunk to check it out. All i found there was a circular plat with three screws. Is that what you used? Did you just un-screw the plate and ground it between the trunk floor and the plate? I ask because my wire comes with a clamp for the ground, and it won't fit there. Can I use the ground wire w/o the clamp?
Re: Re: Re: Re: Need help re-wiring!
Originally posted by icy CL
the clamps or wire post connectors are used to get a good, tight, secure install when screwing it in. you don't need to use these clamps but if you are going to bolt it down, better to use it. if you are jsut gonna put the wire btwn the plate and chassis, you can remove the clamp.
Re: Re: Re: Re: Re: Need help re-wiring!
I think I am gonna use the clamps for a more professional install. So, using the clamps, what can I bolt it down to in the trunk w/o drilling any new holes??
jeedo6
08-29-2015 07:28 PM
