Need help for picking electric switch
i rqn 8 gauge wire to my trunk dirrectly from my battery to my 750W power inverter which has two 50 amp fuses. i want to install a switch by my dash so i can turn the inverter from the front of my car instead of going to the trunk to do it. do i need a hundred amp switch.
i am plugging my computer into it
i was gonna get the Hella Contour Master Power Switch
http://robotcombat.com/marketplace_switches.html
A relay is basically a remotely operated switch. You can use a small switch on your dash that sends a signal for the relay to open or close. It would look a lot better but it would cost a little more.
how much more would it cost the switch i found is $22 so if its not gonna cost me like $60 or $70 i would be interested in seeing this contraption.
Here's an example of what you're looking for: http://tswf.com/TIE/relays.cfm
Scroll down to model 24200 (4th one down)
If you want to know how they work, here's a good article: http://electronics.howstuffworks.com/relay.htm
I would say that would be fine for 99.999% of most car uses but he wants a switch that can handle 100A or 1200W. I don't know what kind of alternator he is going to install because I know the stock one can't put out that kind of power but I'm just answering the questions asked....
Well I have an inverter that does not run at full power unless it is required to use that much power so it really only runs at 50 amps which is on one plug and its a computer drawing 250W for the power supply
Barb Jackson
Sep 15, 2015 02:27 PM
