Need help for picking electric switch
Old Mar 17, 2004 | 09:56 AM
CCColtsicehockey's Avatar
i rqn 8 gauge wire to my trunk dirrectly from my battery to my 750W power inverter which has two 50 amp fuses. i want to install a switch by my dash so i can turn the inverter from the front of my car instead of going to the trunk to do it. do i need a hundred amp switch.
Old Mar 17, 2004 | 01:18 PM
Lung Fu Mo Shi's Avatar
Registered AssHat
Think of it this way:
You want your fuses to blow before you switch does in the event of a failure. So yes, I would do a 90 to 100 A swtich.
Old Mar 17, 2004 | 01:29 PM
Dan Martin's Avatar
Photography Nerd
That's a seriously big switch. Where are you going to mount it?
Old Mar 17, 2004 | 02:04 PM
21_in_az's Avatar
Do I Make You Horny?
better question is....what are you going to plug into it?
your computer?
Old Mar 17, 2004 | 03:14 PM
Dan Martin's Avatar
Photography Nerd
I'm thinking a toaster or maybe a hairdryer.
Old Mar 17, 2004 | 06:56 PM
i am plugging my computer into it
i was gonna get the Hella Contour Master Power Switch
http://robotcombat.com/marketplace_switches.html
Old Mar 18, 2004 | 12:17 AM
ortiz's Avatar
Don't listen to me.
Wouldn't putting in a relay be easier?
Old Mar 18, 2004 | 06:00 AM
what would a relay do. exuse my lack of electrical knowledge.
Old Mar 18, 2004 | 08:35 AM
Dan Martin's Avatar
Photography Nerd
A relay is basically a remotely operated switch. You can use a small switch on your dash that sends a signal for the relay to open or close. It would look a lot better but it would cost a little more.
Old Mar 18, 2004 | 08:47 AM
how much more would it cost the switch i found is $22 so if its not gonna cost me like $60 or $70 i would be interested in seeing this contraption.
Old Mar 18, 2004 | 08:49 AM
Dan Martin's Avatar
Photography Nerd
You should be able to do it for less than $50.
Old Mar 18, 2004 | 08:51 AM
Dan Martin's Avatar
Photography Nerd
Here's an example of what you're looking for: http://tswf.com/TIE/relays.cfm
Scroll down to model 24200 (4th one down)
If you want to know how they work, here's a good article: http://electronics.howstuffworks.com/relay.htm
Old Mar 21, 2004 | 12:17 PM
JTso's Avatar
Wouldn't you think SP BRK30 from the first links works better? What you really need is to turn on/off the DC power going to the inverter. Radio Shack should have plenty of automotive relays.
Old Mar 21, 2004 | 01:43 PM
Dan Martin's Avatar
Photography Nerd
I would say that would be fine for 99.999% of most car uses but he wants a switch that can handle 100A or 1200W. I don't know what kind of alternator he is going to install because I know the stock one can't put out that kind of power but I'm just answering the questions asked....
Old Mar 21, 2004 | 02:37 PM
JTso's Avatar
Ah, I see. Damn, that's a lot of power.
Old Mar 21, 2004 | 02:50 PM
Well I have an inverter that does not run at full power unless it is required to use that much power so it really only runs at 50 amps which is on one plug and its a computer drawing 250W for the power supply
Old Mar 21, 2004 | 09:51 PM
JTso's Avatar
Have you considered a laptop computer? It would require a lot less power.
Feb 25, 2020 09:57 AM
F-C
Motorsports News
28
Sep 25, 2019 07:40 AM
F-C
Motorsports News
14
Sep 28, 2015 12:54 PM
Barb Jackson
Sep 15, 2015 02:27 PM
datadr
Sep 2, 2015 06:46 PM
