Need Help NOW ASAP
Old Apr 2, 2003 | 04:33 PM
dnd2984's Avatar
Need Help NOW ASAP
Guys need help ASAP. I got my doors opened up, and cant find a place to mount the crossovers sercurily. Where have people mounted them at. I found I place to mount them on the inside of the door panel but dont know how safe that would be. Any Help will help. Picks and instuctions please.
Old Apr 2, 2003 | 05:46 PM
dnd2984's Avatar
ok I kinda stole your idea ACura X2 on wher to mount it now the door panel wouldny go back on so I had to take that black part near the left of the door that pushed the vapor barrier in, I had to take it out so the panel would fit back on. What is this black piece for and did everyone who mounted crossovers there had to take it out. I took a look at it and it didnt look like it served a purpose. But then again everything serves a purpose.
Old Apr 2, 2003 | 06:11 PM
AcuraX2's Avatar
I am not sure what the black piece is for. I got rid of it. I tried the door panel but, if you need to get to the speakers, you have to either use alot of wire or unhook everything. I think you put them in the best spot for door mounting. I do recall seeing a pic of someone who mounted them right in front and below the speaker but, it was a small xover.
BTW...I stole my idea from someone on here as well who used lexan instead of the aluminum I used.
Old Apr 2, 2003 | 06:58 PM
dnd2984's Avatar
ok thanx man, I just got done with dinner and back to the car now. Now I gotta use alot of wire to get to the crossover. Ok ill keep ya updated tonight, Also sound dampened the door with Rockford Deadskin, No smell and extremely easy to use.
Old Apr 2, 2003 | 11:38 PM
systek's Avatar
this is what i did because you have to make sure to protect the xover from moisture...that is the only reason you dont want to simply throw it in the door w/out protecting it. since i left the plastic in place and didnt use screws, im not worried too much about corrosion. btw, that one piece of duct tape isnt all that is holding it...i went ahead and used two more pieces of tape to make a cross over the xover which has worked just fine.
Old Apr 2, 2003 | 11:46 PM
StreetEffectz's Avatar
Old Apr 3, 2003 | 07:43 AM
dnd2984's Avatar
I am guessing you guys had to rip that plastic piece out the door to? OK so i opened up the driver side door and the damn vapor barrier looks like it melted in there. I just got a new door skin put on due to gettin hit by my sister. If I sound dampen the whole door and just cover the big opening on the left side should I be fine like that?
Old Apr 3, 2003 | 09:19 PM
bozzchem's Avatar
About $10 worth of Lexan from Home Depot and you're done.
Here's what I did: http://www.cardomain.com/member_page...=280779&page=4
Old Apr 4, 2003 | 02:19 PM
dnd2984's Avatar
I would like to thank you all for replying and the install went good. THose Type Rs sound so damn nice, and I have gained tons of mid bass.
njresendez
3G TL Photograph Gallery
Sep 21, 2015 06:32 PM
Skirmich
Sep 15, 2015 06:41 PM
Billu99tl
Sep 13, 2015 11:30 AM
