Need help! IceLink + issue on TSX
I have the icelink+ installed on my TSX for over a year now but since a month ago, I am not able to select the "CD-C" from my head unit when the engine is started but it working fine when the engine was not started. I tried to put the icelink plus on another TSX and all working good. Then I brought my car back to Acura and they tested it with the oem mp3 deck and it working perfectly too! So ne idea what's going wrong!!!
is this right?
your icelink
your car
engine off=>works engine on=>doesn't work
your icelink
friend's tsx
engine off=>works engine on=>works
oem mp3
your car
have you tried keeping the radio off while starting the vehicle, then turn the radio on after the engine started? is the CD-c option available with the engine on, without the icelink installed? if not, its obviously a HU problem. The HU sounds a little flaky as is, but it would be nice trace it down. I don't understand how the HU would forget it has an input with something connected to that input with the engine on. It doesn't seem like it would be a connection issue or a flaky button on the HU. I assume you've tried cycling the radio power while the engine was on?
your icelink
your car
your icelink
friend's tsx
oem mp3
your car
have you contacted the manufacturer of icelink? this isn't Dension is it? If so, i'm not sure what happened to them...
If you can get a firmware update, then its worth a shot.
cycdaniel
12-17-2019 10:58 AM
mugen_kid
11-13-2015 10:38 PM
IndycarFaster
09-11-2015 02:52 PM
