Need help hooking up AMP
Old Aug 20, 2003 | 11:32 AM
I have a 1000 watt amp and two 12' alpine type S subs. I need help on the remote wire. What do I run it to??
Old Aug 20, 2003 | 12:45 PM
d3rk's Avatar
Become Hypnotized
I ran it to a fuse that turns off when the car turns off with a switch huked to it, incase I wanna turn off the bass...Sometimes my g/f gets headaches so I have to turn the bass off...jus my .02...but fair warning if u hook it up to a fuse, u have the chance of when turning off the car ure subs will hit a low bass note for a split second.
Old Aug 20, 2003 | 01:16 PM
TL-IGHTS's Avatar
Registered Abuser
You know the cigarette lighter in the center console, it only supplies power when the car is on. I bought an adapter and just cut off the accessory end and crimped a sleeve connecter on the end. From there, I just ran it thru on of the screw holes, under the carpet straight back, up through the ski hole opening and directly to my amp. I, like d3rk, bought a plug with a built in switch on the back of it so I can cut off the bass whenever I want.
Hope that helped.
Matt
Old Aug 21, 2003 | 01:23 PM
shodawg124's Avatar
you can tap the remote on wire that runs to the stock sub amp (it's the blue wire)... more details can be found here:
http://www.acura-tl.com/forum/showth...threadid=37582
Jul 16, 2017 07:33 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
AcuraKidd
Sep 25, 2015 11:18 PM
