Need help hooking up AMP
Become Hypnotized
I ran it to a fuse that turns off when the car turns off with a switch huked to it, incase I wanna turn off the bass...Sometimes my g/f gets headaches so I have to turn the bass off...jus my .02...but fair warning if u hook it up to a fuse, u have the chance of when turning off the car ure subs will hit a low bass note for a split second.
Registered Abuser
You know the cigarette lighter in the center console, it only supplies power when the car is on. I bought an adapter and just cut off the accessory end and crimped a sleeve connecter on the end. From there, I just ran it thru on of the screw holes, under the carpet straight back, up through the ski hole opening and directly to my amp. I, like d3rk, bought a plug with a built in switch on the back of it so I can cut off the bass whenever I want.
Hope that helped.
Matt
Hope that helped.
Matt
you can tap the remote on wire that runs to the stock sub amp (it's the blue wire)... more details can be found here:
http://www.acura-tl.com/forum/showth...threadid=37582
InFaMouSLink
10-30-2015 09:43 AM
AcuraKidd
09-25-2015 11:18 PM
