CL: need help hooking up 3 wires (aftermarket navi)
Old Sep 12, 2010 | 04:09 AM
havieri23's Avatar
i have an eclipse avn6620 hooked up. 3 color wires i don't know where to hook up, if it's located anywhere near the center radio so i can just tap it close. the speed pulse sensor, the parking, and the reverse.
Old Sep 12, 2010 | 09:30 PM
totaledTL's Avatar
Year model? Try looking here: http://www.the12volt.com/installbay/...ard/Acura.html
Old Sep 13, 2010 | 05:54 AM
havieri23's Avatar
..all i found is this SPEED SENSE|blue/white | |cruise control module *5 |
Old Sep 23, 2010 | 08:23 AM
havieri23's Avatar
anyone?
Old Sep 26, 2010 | 07:16 PM
Blazin Si's Avatar
Speed sensor is probably in the cruise control module like you said. I by-passed the parking brake, but the reverse wire for the navi was extra long, so I ran it to the reverse lights like it was intended.
Old Sep 27, 2010 | 11:28 PM
havieri23's Avatar
i found the speed sensor wire where its' suppose to be. just grounded the brake wire to a bolt...read somewhere the reverse wire was under the passenger fuse box in the kickpanel (brown plug gree/blac wire)...opened it up..found a brown plug with that color wire, tapped it..wrong one..didn't see any other brown plug..had to disconnect..gps was going backwards..anyone got a pick of the plug..running all the way to rear seems tedious. anway to tap it near the shifter?
Jul 16, 2017 07:33 AM
vpasla1
Sep 17, 2016 07:24 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
