need help...double din bracket
Old Aug 26, 2001 | 11:58 PM
yee's Avatar
yee
I'm planning on getting a double din system to replace my original,
does anyone know where I can find a braklet for it?
any help would be appreciated, thanks!
Old Aug 27, 2001 | 11:57 PM
StanMan's Avatar
since the radio faceplate is unconventional, more than likely you will need to go with a custom piece...and depending on how you mount that double din unit within the void, the faceplate design can vary. mounting the unit on center widthwise, but all the way at the top would require a U-shaped faceplate. mounting on center width- and height-wise will require a perimeter plate. just trace the face of the stock radio and go from there if you want to try first.
but if you want a pro to do it, you can give my buddy a call. he had done a faceplate for my accord when i mounted 2 single din units and has made faceplates for many other kinds of cars...
tai, ben stereo, city of industry, 626/336-3327, northwest corner of gale and stimson.
Old Aug 28, 2001 | 03:02 AM
yee's Avatar
yee
thanks! do you know how much it would be?
cuz I got a quote up here for an aluminum cast for $200
Old Aug 28, 2001 | 09:28 PM
Edub-TL's Avatar
Sticky Rice OwnZ joO
yee,
what are your plans for the stock TL-S HU??
Hook a brotha up!!
Old Aug 29, 2001 | 03:25 AM
yee's Avatar
yee
sure, I'll PM you soon as I plan to get rid of it.
Old Aug 29, 2001 | 09:17 AM
StreetEffectz's Avatar
No need for a custom bracket....you can use the one off the factory headunit. I did several aftermarket TL installs already using the existing cage in the car. All you will need to make is a faceplate.
Old Aug 29, 2001 | 02:24 PM
yee's Avatar
yee
Ron...I was hoping it would come to you.
do you know where I can get the faceplate?
do you make them? if so how much??
thanks.
Old Aug 29, 2001 | 05:45 PM
I do make them. Since you are in california, what I would ask you to do it this...once you have the headunit mounted, make a template out of cardboard and send it to me. Reason being is because I don't know exactly where your headunit it going to sit, know what I mean?
Old Aug 29, 2001 | 08:52 PM
yee's Avatar
yee
thanks! I'll contact you soon as I get them.
Old Aug 31, 2001 | 06:14 PM
96TL's Avatar
Ex-Mod
Like mine.
Soul_Deamon
Nov 13, 2018 04:44 PM
Jul 16, 2017 07:33 AM
jmaxima03
Sep 27, 2015 10:22 AM
urbtsx
Sep 27, 2015 09:40 AM
