Need help on auto starter in Toronto
1. can anyone recommend me any place to install auto starter professionally with reasonalbe price?
2. is auto starter good for the car, what are the pros and cons?
3. how does auto starter work with our acura key unit and if comes with the alarm, does that mean the fatory key lock will not work any more?
4. i heard it's bad if we leave the air condition/heater on or stereo before we turn off the car. is it true?
And I thought only Americans were fat and lazy.
Autostart = sign of the apocalypse.......
......I think I'm gonna get one too, but for the '05 CRV I just bought for my wife - same engine, same transmission. Try a search - this subject has been brought up before. Be very carefull on install, a friend of mine had nothing but problems after he had a system (dunno what brand) installed at Best Buy.
iceboy1,
Do you have the AT?
You post a good question. Be very careful with such add-ons because they can be very risky. I plan to attend a meeting, and catered dinner, sponsored by my dealer this Thursday. I made a note to ask the maintenance manager about remote start; do they recommend any, do they install any?
I would not trust a store like Best Buy to install anything on my car. I would like for higher end shops and perhaps a custom shop where the owner is also one of the installers.
It is my practice to turn off the AC, and the stereo, before I turn off the car; so that would not be an issue with me. I don't know about the stereo, it I recommend that the A/C be off when you start a car to reduce the load on the starter motor as well as the engine when it first fires.
Do you have the AT?
Originally Posted by Jim Holloman
iceboy1,
Do you have the AT?
Do you have the AT?
first, you will need a key transponder bypass module to defeat the transponder in the key.
second it is usually reccommended you install it on an Auto transmission car. though i have done several manuels with a neutral safety switch.
third. if your turning off the HVAC system every time you get out your a nut case! the AC compressor of any modern car is controlled by the ECU of the HVAC system it is also tied into the engine ECU. the compressor does not come on until the engione has already started for 2 reasons.
1 the ECU wont allow that to happen untill a few seconds after the car starts.
2. the ignition is wired so that the HVAC as well as radio and other accessories are turned off when you turn the key to the start position. there is only 1 and on some cars 2 wires that get 12volts while cranking and they are 1. ignition and fuel pump 2. the ECU some cars only use 1 wire for both like subarus do.
all other accessories of the car are turned off because the ACC wire of the ignition switch is DEAD the second you turn the key past the run position.
next time try starting the car without pushing in the clutch all the way or for a auto trans put the shifter in gear (both will prevent the car from starting because of the neutral safety switch) you will notice wthat even with the HVAC and radio on these items will go dead while you hold the key in the start position. but the starter will not turn because of the neutral safety switch)
there is no need to turn anything off after you turn your car off. doing that will eventually wear the off button out or rub the lettering off the button if you press it every time you get out.
2) Starters are good for the car IF INSTALLED PROPERLY. Skimping on price often results in hack installs and those are NOT good for the car.
3) The bypass module is needed, your good install shop has them in stock, no problem, don't worry about it, slight additional cost.
4) Not true. If it were true car starters would have died off.
Originally Posted by domn
Try Art of Noise in Brampton. I've had some work done there in the past on my Civic and Integra (Alarms) Good prices and good service, though I havn't been there in about 4 years.
Originally Posted by elduderino
1) Toronto posters? (Please remember - good - fast - cheap - pick any two...)
Most every newer car has some kind of low-power transmitter chip in the head of the key. The transmitter is powered by an electrical field generated by a loop of wire, and the signal is also picked up by an antenna in the steering column. You won't pick it up outside the car - range is a few inches. There are supposedly millions of codes available.
If the code is not received the car won't start, even if a physical key replica is inserted.
Bypass modules enable starting, either with a valet key concealed or by replicating the OE signal in a learning-remote sort of manner.
Originally Posted by hamidreza78
Hey whats a bypass module?
1 requires a blank and programmed key be installed into a small box under the dash.
the other learns the code of your keys and replicates it.
lanechanger
10-13-2015 10:56 AM
