Need help with Alpine amp....
Old Jul 24, 2004 | 01:29 AM
andgo2's Avatar
I have an 2-channel amp Alpine MRV-F1507 powering one sub. I recently blew my sub and replaced it with a brand new sub but still no sound.
I have 3 status indicators on the amp: 1. PROTECTION 2. MUSIC 3.POWER. The protection and music indicators are both green but i have a constant RED light for the Power indicator which should be green when everything is fine. According to the manual it means i have a blown fuse or a poor battery connection. I replaced the fuse and checked the voltage at the amp. Readings were fine, 12.5v with the car off and 14.4v when running.
Pls help!!! –
Old Jul 24, 2004 | 10:16 AM
tsill's Avatar
not sure if the protection circuit has a reset for that amp. possibly your battery and ground wires are crossed. i've done that before becuase i used the same color wire. is your remote turn on wire connected. its the blue wire on the amp that should receive 5 volts from the head unit.
Old Jul 24, 2004 | 11:08 AM
shawhite's Avatar
there should be a fuse on the side of the amp.. check that to make sure it is not blown..
Jul 16, 2017 07:33 AM
yahelou
Sep 6, 2015 09:12 PM
StreetEffectz
May 9, 2002 12:04 AM
CarFreak_RENAMED
Feb 12, 2002 03:49 PM
