Navigation Sound / Aftermarket Amp
If I use the stock HU, line level convert the signal (to RCA), send it to an aftermarket amp, new wires to the door speakers, will I lose the navigation audio?
Should I covert the signal after the EQ? Where does the navigation audio tap into the door speakers?
Brian
Brian
should i send the wires from my aftermarket amp back up to the HU and tap into the harness there? This way I can keep all ther factory wiring and keep the navigation audio?
Please help!!!
Thanks,
Brian
Please help!!!
Thanks,
Brian
I did a search and got some mix results. From what I gather, the Nav audio is pumped into the system through the factory HU. If I covert the signal out of the radio (prior to the EQ) I should retain the audio.
I'm just wondering if the audio is pumped into the system after the HU. Or is the Navi audio pumped directly into the speakers? I don't know... hehehe.
Someone help.
Brian
Someone help.
Brian
Brian,
The Navi signal is sent to the HU. So if you do as you described, you will not lose nav audio.
I ran two pairs of speaker wire from my amp to the harness up front and tied into the factory wires to drive my fronts. The rear channel was tapped into behind the inertia reels.
are you planning on bypassing the EQ?
Here's my install:
clicky
Good luck.
Iggy
Here's my install:
clicky
Good luck.
Iggy
Originally posted by Brian_C6
Yes. I don't plan on using the EQ. Anything special I need to know?
Brian
Brian
It sounds like you are planning to get the signals from the speaker outs which should work w/out the bypass if you plan on keeping the stock speakers. If you plan to upgrade the speakers, though, you might consider it. The factory EQ will make aftermarket speakers sound very "tinny". Also, if you keep the factory speakers(which are very cheaper paper cones), be carefull how much power you throw at them.
Cheers,
Iggy
AndrewS
19
03-14-2024 06:59 PM
trinikidcl
09-04-2015 12:56 AM
