NAvi conversion problem
Old Sep 4, 2004 | 12:50 PM
I installed VSokolovs conversion kit and for some reson now I have lines (noise) on my navi screen
PLEASE SOMEONE HELP
What should I do?????
Old Sep 4, 2004 | 01:57 PM
Jonesi's Avatar
Check your ground..
Contact Vsolokov..
Any problems with the install? Anything you weren't sure about?
Any pics?
Old Sep 4, 2004 | 02:32 PM
Everything was OK.
I connected everything and soldered every connection.
I was getting noise in my speakers but after I grounded my DVD everything was ok.
Now another problem - when the engine is running I am getting small horizontal lines on the screen.
As far as I know navi conversion kit has a ground wire (black one with letters) which I connected to navi according to instructions...
Not sure what else I should ground
I am so mad. I dont want to ripp apart the whole install... HELP!!!
Old Sep 4, 2004 | 02:39 PM
chabanais's Avatar
Sounds like it to me that you are getting noise interception from the engine. The same thing can happen with stereos.
Old Sep 4, 2004 | 02:53 PM
mrsteve's Avatar
Try a different ground...
Old Sep 4, 2004 | 03:09 PM
Jonesi's Avatar
Originally Posted by PhillyTL-S
Everything was OK.
There should be a ground also for the A/V switch.. It's defintley a grounding issue with the way you are describing.. If you fix it or have anymore questions post up..
Old Sep 5, 2004 | 11:27 PM
Has anyone installed VSokolovs conversion module without any ground issues (noise on Navi Screen) ???
Old Sep 6, 2004 | 09:28 AM
withoutcomp1's Avatar
Get a noise filter from radio shack or a local car stereo store and put it between the constant power and ground leads of the conversion unit sometimes it works sometimes it won't, it's worth a try!
HondoGermany
23
Jan 8, 2016 03:01 PM
MoAbbas
Oct 3, 2015 07:44 AM
Vejey Gandier
Sep 12, 2015 08:59 PM
ivegotthenav
Sep 11, 2015 07:51 PM
Gianni Formica
Sep 7, 2015 08:28 PM
